How to lower Temps. GPU
carlos726811
Hey all. Specs below of the pc i have.
Was wondering if anyone got any tips/guide how to lower GPU temps. Reason Being. When idol Temps running 57+c When gaming 70+C. From what i seen/read. People saying those temps are high. Does anyone else agree or would you say temps are fine.
Case CORSAIR CRYSTAL SERIES 680X RGB GAMING CASE
Processor (CPU)AMD Ryzen 9 3900X 12 Core CPU (3.8GHz-4.6GHz/70MB CACHE/AM4)
MotherboardASUS® ROG STRIX X570-F GAMING (USB 3.2 Gen 2, PCIe 4.0) - ARGB Ready!
Memory (RAM)32GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 8GB)
Graphics Card10GB NVIDIA GEFORCE RTX 3080
1st M.2 SSD Drive1TB SEAGATE FIRECUDA 520 GEN 4 PCIe NVMe (up to 5000MB/R, 4400MB/W)
1st Storage DriveNOT REQUIRED
DVD/BLU-RAY DriveNOT REQUIRED
Processor CoolingCorsair H115i RGB PLATINUM Hydro Series High Performance CPU Cooler
LED Lighting2x 50cm RGB LED Strip
Wireless Network Card10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED)
CaseCORSAIR CRYSTAL SERIES 680X RGB GAMING CASE
Those temps are really healthy. Anything under 80 is a bonus when gaming.
That's running brilliant TBH. If the temps were below 70 on air, on load, I would say that something was holding the card back power wise.
