hows this for a pc to run siege?
Ezrafade
PCS ENIGMA 6003B BLACK CASE
AMD Ryzen 5 1600X Six Core CPU (3.6GHz-4.0GHz/19MB CACHE/AM4)
ASUS® PRIME A320M-K: Micro-ATX, AM4, USB 3.0, 6GB/s
8GB Corsair VENGEANCE DDR4 2133MHz (2 x 4GB)
6GB NVIDIA GEFORCE GTX 1060 - DVI, HDMI, 3 x DP - GeForce GTX VR Ready!
1st Hard Disk
2TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE
M.2 SSD Drive
128GB M.2 2280, SATA 6Gb/s (560MB/R, 467MB/W)
DVD/BLU-RAY Drive
STANDARD AMD CPU COOLER
EK-TIM ECTOTHERM THERMAL COMPOUND
Genuine Windows 10 Home 64 Bit - inc DVD & Single Licence
DVD Recovery Media
Windows 10 (64-bit) DVD with paper sleeve
Monitor Cables
1 x 2 METRE DVI-D CABLE
Keyboard & Mouse
CoolerMaster Devastator III Combo Keyboard and Mouse
Standard Build - Approximately 14 to 16 working days
Quantity
1
Price £988.00 including VAT and delivery
Overall spec seems decent.
I'd have suggested dropping the M.2 SSD as it's small, relatively slow, and a bit of a waste of an M.2 slot.
The better thermal paste isn't really worth it either since you're only going with a stock cooler. If you were going to spend more on cooling, I'd probably suggest a better cooler first, and then worry about the paste. But the stock cooler and stock paste will do fine for now.
You could invest what you save into a better motherboard like thew B350-F which has USB 3.1, more expansion and upgrade options, better onboard sound, and unlike the A320 series supports overclocking. You can easily add an SSD as a future upgrade.
Alternatively, you could keep the cheaper mobo and switch the M.2 SSD to a 256gb PM961.
