I have:
Ryzen 1700<cpu>
ASUS PRIME B350-PLUS <motherboard>
ddr4 running at 2133 speed but actualy rated at 3000
EVGA 600 W1, 80+ WHITE 600W <power supply>
Bitfenix neo <case>
zotac mini GTX 1080<gpu>
Corsair Hydro Series H55<cpu cooler>
hope that helps...
As the forums belong to PC Specialist who build and sell custom PCs and laptops we can't advise on self build projects or competitors' specs.
You'd need to try an open forum like Tom's Hardware. You'll also need to tell them what you use the system for if you want advice on whether upgrading X component is 'worth it'. If it's gamong on a 1080p 60hz monitor the answer is probably no...
