I need help building a PC
What's it going to be used for, do you have mouse and keyboard etc, what are the monitor specs, resolution and refresh rate or make and model, and as the budget is in euros what country are you in
danielps
It will be used for gaming and general everyday use.
I have 2 MSI G27C4 monitors and the specs are 1920 x 1080, 165Hz.
I am in Ireland.
Ok this should do nicely
CORSAIR iCUE 465X RGB GAMING CASE
ASUS® TUF X570-PLUS GAMING WIFI (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - RGB Ready!
500GB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7000MB/R, 3000MB/W)
Corsair H100i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Firefox™
Price: €2,479.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/XTuH52C0PP/
MrWilson
Godlike
Looks like @Martinr36 has gone down a very similar direction to me.
Either build will smash gaming, and will just need a GPU upgrade if you wanted to upgrade to a higher resolution down the line.
CORSAIR iCUE H150i ELITE LCD Display RGB CPU Cooler
NO RECOVERY MEDIA REQUIRED
Christmas Delivery No Longer Guaranteed - Assembly From 29/12/2021
Price: €2,616.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/SUC6BnqR2E/
danielps
Firefox™
Thank you!
danielps
Thank you!
JUNI0R
@MrWilson with the 2 165 Hz monitors in there i've already bumped the GPU to the 3060Ti
Unless OP plans on dual screen gaming (in which case I totally agree with the 60TI move), having Discord or Spotify open on another screen requires very little graphically and wouldn't take much away from the performance of the 3060 which is already at the top of the 1080p performance bracket anyway.
Alternatively, with the huge budget you have @danielps you could totally go for a PC and monitor upgrade. 1440p is a big step above 1080p and a swap I'd suggest making if you can. Monitors wise, for 1440p ~144hz, our current go to pick is the Gigabyte M27Q, a fantastic value IPS monitor. Depending on what you play going for an ultrawide could be a good move. The Gigayte M34WQ-EK is a great IPS option and is owned by a very satisfied @Martinr36. Although worth noting that I believe the Iiyama GB3461WQSU-B1 uses the same panel and is more than £100 cheaper.
Any questions, ask away!
CORSAIR 4000D AIRFLOW TEMPERED GLASS GAMING CASE Brilliant high airflow case
AMD Ryzen 7 5800X Eight Core CPU (3.8GHz-4.7GHz/36MB CACHE/AM4) Solid 8 core AMD CPU
ASUS® STRIX B550-F GAMING (DDR4, USB 3.2, 6Gb/s) - ARGB Ready! High quality motherboard to handle the 5800X
16GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (2 x 8GB) Will be plenty to handle the vast majority of gaming
8GB NVIDIA GEFORCE RTX 3070 - HDMI, DP, LHR Will smash through 1440p and quite competently handle 1440p UW
500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W) Super fast boot SSD for Windows and applications
1TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2500MB/sW) Speedy games drive
CORSAIR 1000W RMx SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET High wattage PSU to allow for plenty of future upgradability
Corsair H150i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler Top end CPU cooler for the 5800X, you could get away with the H100i, but the H150i will look great in the front of the 4000D
WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0 The motherboard doesn't have onboard wifi so you'll need a card, this is all the WiFi card you'll need
Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001] I'd stick to W10 for the time being
NO ANTI-VIRUS SOFTWARE Windows Defender is a perfectly acceptable AV
3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) Well worth the 7 euros
Price: €2,553.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.ie/saved-configurations/amd-am4-gen3-pc/6mP5z0xuAv/
danielps
Thank you!
