I9 9900k OC help | PCSPECIALIST
I9 9900k OC help
G1llam
Hi guys I’m thinking about over locking my i9 9900k to 4.9ghz but was wondering how to do it and if it was safe and stable?
thanks for your reply’s in advance
It's not something we can teach, it's not something you can just pre apply, it's a gentle incremental group of steps you take to achieve the max overclock for that particular piece of silicon. Every chip is different so you have to come at each like a new overclock and start from scratch.
It's not something we can teach on this forum, you'd need to ask somewhere like Tom's Hardware which is an open forum.
There are plenty of guides on youtube also.
G1llam
Rightio, thanks
Also if you overclock your 9900k to 4.9Ghz you're actually locking it to a lower frequency than it would boost some of its own cores to.
What would the best ghz to oc too that’s still safe and stable @Oussebon
That's the point, it's not something we can tell you, it's something you have to find out for your chip. As said previously, every chips different, some will overclock easily by miles, others won't overclock at all.
G1llam
Would a Hydro Series H100x High Performance Liquid CPU Cooler be enough to keep it cool if I oc it or would I have to find out.
sorry for big letters I c+p
Yep, personally I'd go with the H100i as a minimum, the x doesn't have software monitoring.
Not what you want to hear, but with overclocking, going slowly, making small, incremental changes and testing for stability between each change. There are a lot of guides out there.
What is safe and stable will vary according to your setup, and indeed your specific CPU. And I don't mean the 9900k, I mean each single 9900k will behave a little differently to every other 9900k.
The H100x won't cut the mustard for a meaningful overclock. You would want to be running 5Ghz on all cores for there to be any point in doing it at all. At this point, the chip runs proper hot and needs some very good cooling.
I stress tested at 5.2Ghz on my chip and I was hitting 100°C on a H115i RGB Platinum (The best, IMO) at full chat. I pulled it back to 5.0Ghz for daily running and it has been great, with very reasonable temperatures even under heavy load. The H100x wouldn't get you that.
I would stick with stock speeds as clocking the chip at 4.9Ghz hampers your single thread performance. If you are into development or etc then it may be worthwhile but if you are an avid gamer I would just leave it as it is.
G1llam
Thanks for the reply.
G1llam
I’ve just amended my order by changing my storage options from an ssd to a m.2 and a 1tb hdd and was wondering if the operating system would come installed on the m.2 ssd instead of the 1tb hdd? @Oussebon @SpyderTracks
It usually wouldn't, if the system is till pre-production.
What is your full spec and what are you using the system for?
G1llam
cant remember the name of the monitor but some sort of 4K gaming one.
CaseCOOLERMASTER MASTERBOX MB530P RGB GAMING CASE
Processor (CPU)Intel® Core™ i9 Eight Core Processor i9-9900K (3.6GHz) 16MB Cache
MotherboardGigabyte Z390 AORUS Master: ATX, LG1151, USB 3.1, SATA 6GBs WIFI - RGB Ready
Memory (RAM)16GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (2 x 8GB)
Graphics Card11GB NVIDIA GEFORCE RTX 2080 Ti - HDMI, 3x DP GeForce - RTX VR Ready!
1st Storage Drive500GB SEAGATE BARRACUDA 2.5" SSD, (upto 560MB/sR | 535MB/sW)
Change to: 1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE
2nd Storage Drive1TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE
Change to: NONE
1st M.2 SSD DriveNONE
Change to: 500GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3200MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 650W VS SERIES™ VS-650 POWER SUPPLY
Processor CoolingCorsair H100x Hydro Series High Performance CPU Cooler
Wireless/Wired Networking10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED)
Office SoftwareFREE 30 Day Trial of Microsoft® Office® 365 (Operating System Required)
Anti-VirusBullGuard™ Internet Security - Free 90 Day License inc. Gamer Mode
BrowserGoogle Chrome™
Warranty3 Year Standard Warranty (1 Month Collect & Return, 1 Year Parts, 3 Year Labour)
Build TimeStandard Build - Approximately 5 to 7 working days
Promotional ItemChoose from 6 Incredible Ubisoft Titles FREE with select SAMSUNG SSDs!
Promotional ItemFREE Red Dead Redemption 2 & More! w/ select Intel i7 & i9 CPUs!
