3qtrsamericano
Well, almost 1.5 months later and it's still the same. Part is on the site but no option to actually purchase. May just have to give them a call.
Yeah, do, they don't sell direct, it's all done through secondary suppliers.Well, almost 1.5 months later and it's still the same. Part is on the site but no option to actually purchase. May just have to give them a call.
Ah, found the post with a little search, it's here with the steps he took:Yeah, do, they don't sell direct, it's all done through secondary suppliers.
But we did have a guy contact them and they sent him a few free.
Tell ‘em the lads at PCS sent you. And they’ll throw in an MM700 too if they know what’s good for them…May just have to give them a call.
Tell ‘em the lads at PCS sent you. And they’ll throw in an MM700 too if they know what’s good for them…![]()
I meant get them to throw it in for me. My desk area doesn’t glow enough already. HonestDon't need the mouse pad but hey look! I can order it!![]()
Pennywise (Tim Curry's original) still gives me nightmares, I loved those films!That said. Son's into horror movies - Pennywise and Michael Myers as the two faves (yes, bad parenting. I know!). Would be cool to get one of those custom printed![]()
Thanks for that. made me notice I hadn't configured the lighting node pro in W11I meant get them to throw it in for me. My desk area doesn’t glow enough already. Honest![]()
I came here to chew bubblegum, encourage RGB, and teach good cable management… and I’m all out of bubblegumThanks for that. made me notice I hadn't configured the lighting node pro in W11
1 out of 3 ain't badI came here to chew bubblegum, encourage RGB, and teach good cable management… and I’m all out of bubblegum![]()
You can now select if you want PCS or Corsair branding in the configurator. So if you ordered before this just amend your build to the Corsair branded kit.My new machine is ordered and will no doubt have the PCS logo on the corsair product. It's a stupid idea on PCS part. I have a few corsair fans going into it and already its going to look like a pick ' n 'mix of parts. I am looking forward to the machine, but it is going to look off. I suppose its how PCS want to rock new machines by trying to re-brand them.
FWIW, I wouldn't care if the entire inside was branded corsair or PCS...but now I will have both, on a machine costing over 4.5k....its a bit of a joke....but I am stuck for a PC. If I wasn't, I'd have explored other options.
I was only aware this being the case on the H115i CapellixYou can now select if you want PCS or Corsair branding in the configurator. So if you ordered before this just amend your build to the Corsair branded kit.
I think it's only the 280mm fan that has the Corsair fans. I might swap out the 360 and go with the 280mm kit.You can now select if you want PCS or Corsair branding in the configurator. So if you ordered before this just amend your build to the Corsair branded kit.
It's perfectly reasonable for a SI to brand their kit. PCS happen to do it less than most places.I think it's only the 280mm fan that has the Corsair fans. I might swap out the 360 and go with the 280mm kit.
It's a nightmare what PCS are at. I've never had so much confusion over a purchase in my life. All I want is brand consistency within the visible parts of the case, especially the fans, be it PCS or corsair.
As I mentioned above, I don't care what branding it is. All I want is consistency, and not a pick'n mix. If an SI are to brand stuff, they should brand everything. As it sits, I will have corsair branded case fans, PCS branded case(I think), PCS branded cooler plate, PCS branded cooler fans (I think), Corsair branded additional fans LL120's.It's perfectly reasonable for a SI to brand their kit. PCS happen to do it less than most places.
If you're not happy with it, go elsewhere.
If this is true, I will be happy - as all fans will be corsair branded in this case. The cooler I bought was the 360mm corsair capellix. In the images it looks like it has the PCS branding on the fans...but I cannot be sure. This is why I was considering changing to the 280mm cooler, as it appears that has an option of corsair branding...The PCS Sticker on a case can just be taken off
The only other thing branded will be the pump cap on the CPU cooler which can be changed easily. Unless you bought actual PCS branded fans they should have the corsair branding
