counterman2
Basic pc spec;
Windows 7 64bit
I5 2500
p8h67 M LX
8gb ram
gtx 560ti
COOLERMASTER ELITE 310 BLUE CASE.
stock cpu fan
I bought my pc a year ago(from pc specialist, obviously) and I haven't had any problems so far. I thought I would try and update my bios so I installed AI suit 2. I had no luck updating the drivers from the internet, it couldn't connect to the server, it didn't bother me, but that's not the problem.
I was running some software and AI suite warned me that my cpu had reached 60c, so I done some testing with core temp and prime 95, and now I'm a little worried. Core temp says my idle temps for my cores vary from 37c to 40c, I think that's within acceptable margins so that's o.k, my idle cpu speed is 34c according to AI suite. However when I run prime 95, with all cores at 100% all 4 cores heat up to over 80c and average between 84 and 87, one core even went to 92c but that was only briefly before the fan kicked up, that's what the cores were at during prime 95, the cpu temp was 63c when running this test, according to AI suite.
I understand that my cpu cores would never reach those high's during gaming, my pc has never crashed due to overheating either. I checked my cpu and the fan is on right and all that.
So am I getting paranoid, or is my cpu in peril?
Windows 7 64bit
I5 2500
p8h67 M LX
8gb ram
gtx 560ti
stock cpu fan
