Intel Rapid Storage Issue | PCSPECIALIST
Kiwi
Trying to update to latest version of W10, but getting the Intel Rapid Storage issue. As far as I can see this isn't even installed. Storage controller is MS and PC doesn't have Optane.
Suggestions welcome.
Thanks
Have you read this thread?
Kiwi
Yes, I saw that thread, but I don't have Intel IRST driver in Device Manager and don't believe I have Optane cache, so don't know why/where the update is actually failing :unsure:
Huntsman
That was the same for the other thread. He re ran it and it installed.
Kiwi
OS Name Microsoft Windows 10 Home
Version 10.0.17134 Build 17134
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name DESKTOP-VJ8AGRS
System Manufacturer PC Specialist LTD
System Model FusionIII 22
System Type x64-based PC
System SKU 1355489
Processor Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s), 4 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 3601, 12/12/2017
SMBIOS Version 3.0
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer ASUSTeK COMPUTER INC.
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Desktop
Secure Boot State Off
PCR7 Configuration Elevation Required to View
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "10.0.17134.858"
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 15.9 GB
Available Physical Memory 11.5 GB
Total Virtual Memory 18.3 GB
Available Virtual Memory 13.7 GB
Page File Space 2.38 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Device Encryption Support Elevation Required to View
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware No
Hyper-V - Data Execution Protection Yes
Huntsman
System SKU 1355489
SMBIOS Version 3.0
BIOS Mode UEFI
That doesn’t really list any of your hardware, can you list your specs from your order?
Kiwi
Chassis & DisplayFusion Series: 21.5" Non-Touch Full HD Screen (1920 x 1080)
Processor (CPU)Intel® Core™ i5 Quad Core Processor i5-7500 (3.4GHz) 6MB Cache
MotherboardASUS® H110-T: (Mini-ITX, DDR4, USB 3.0, 6Gb/s)
Memory (RAM)16GB Corsair 2133MHz SODIMM DDR4 (1 x 16GB)
Graphics CardIntegrated Intel® HD Graphics
1st Storage Drive1TB WD BLACK 3.5" WD1003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
DVD/BLU-RAY DriveUltra Slim 8x SATA DVD±R/RW/Dual Layer (+ 24x CD-RW)
Memory Card ReaderIntegrated 4 in 1 Card Reader (SDXC/MMC/MS/XD)
Power Cable1 x 1 Metre Cloverleaf UK Power Cable
Sound Card2 Channel High Definition Audio + MIC/Headphone Jack
Wireless/Wired NetworkingGIGABIT LAN & WIRELESS INTEL® AC-8265 M.2 (867Mbps, 802.11AC) +BT 4.0
USB/Thunderbolt Options4 x USB 3.0 PORTS + 2 x USB 2.0 PORTS AS STANDARD
Looking at a later the later post, I guess this means downloading the latest ISO?
