iPad problems
Jack Guinea
I've got a 1st gen iPad and for a little while now it does this thing where ill be searching the internet on browsing YouTube then it just closes it and goes to the homepage, now its really bad, i cant search the internet, i cant browse YouTube and when i got on the films on my iPad it does the same thing. Anyone got any solution's or advice?
steaky360
Aye reset to factory settings and start again might be an option.
I guess the elephant in the room would be to suggest not using an iPad... but that doesn't really solve the problem.
LFFPicard
Godlike
I had something similar with my iPhone, I just done a backup and restore and it seemed to work.
I found sometimes it could be a app installed as after I done the restore it worked fine on factory settings until I restored my backup then it broke again. In the end I stripped all the apps out and only had what I really use and it seems to be fine now.
