Is my cooling enough to overclock?
L33s2good
My system is :
ANTEC NINE HUNDRED TWO - UK, The Ultimate Gaming Case, Evolved
AMD PHENOM II X6 1090T (3.20GHz/9MB CACHE/AM3/) - BLACK EDITION
ASUS® CROSSHAIR IV FORMULA: DDR3, USB 3.0, SATA 6.0Gb/s, R.O GAMERS
4GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz (2 x 2GB KIT)
1GB AMD RADEON™ HD 6850 PCI EXPRESS - DirectX® 11, Eyefinity 3 Capable
Change to: 1GB AMD RADEON™ HD6870 - 2 DVI,HDMI,2 mDP - DirectX® 11, Eyefinity 4 Capable
2nd Graphics Card
NONE
3rd Graphics Card
NONE
Memory - 1st Hard Disk
1TB SERIAL ATA 3-Gb/s HARD DRIVE WITH 16MB CACHE (7,200rpm)
Change to: 1TB WD CAVIAR GREEN WD10EARS, SATA 3 Gb/s, 64MB CACHE
2nd Hard Disk
NONE
RAID
NONE
1st DVD/BLU-RAY Drive
2nd DVD/BLU-RAY Drive
NONE
CORSAIR 650W TX SERIES (TX650) 80+ ULTRA QUIET PSU (£76)
Sound Blaster® Audigy™ SE (£19)
Network Facilities
And my question is if i overclock with my CROSSHAIR IV FORMULA motherboard by how much could i do so? and would it be safe with my powersupply and cpu cooling i did pay extra for my cpu cooler but wondered if its enough, any tips would be great thank you
lee:cool:
PCS
Administrator
Staff member
It can be overclocked, but keep an eye on the temperatures as the CPU cooler is not recommended for serious overclocking. You may also wish to invest in some better CPU paste to ensure the contact is kept as good as possible.
BAD SANTA
I don't know much about AMD mate so I might not be too much help but one thing I do know is that a lot of it will depend on ambient room temperature if it's in a warm room then you will never get great temps with whatever you use. I would have thought you could go to 4ghz with that case and cooling though, Although you won't get the ram to go at full speed. You could do 3.8 easy and your ram would be at recommended speed as well, also if you select the PCS overclock option they will do it for you for like £10 with better thermal paste.
Hope this helps.
