Tysuro
Hi guys, as the title suggests I was hoping to get an insight into how PCS OC works.
1: Do PCS manually overclock the CPU through the mobo or do they use software like AI Suite from Asus? I like AI Suite the OC only kicks in when it's needed .
https://www.youtube.com/watch?v=Oxd651HEsXE
2: Do PCS provide a USB of sorts with the BIOS settings incase of reformatting/issues or something?(totally new to Overclocking concept forgive my noobness please I'm not keen on messing with the BIOS I've done it before and it's easy but last thing I wanna do is brick the board. I'm a super novice
3: I use my PC for long periods of time and I'm a little worried about the lifespan of the CPU should I be worried?
4: Last question. Are you allowed to select the Overclock speed PCS set? I don't want to go above 4Ghz ideally since I don't really need anything higher thats an ideal number.
