Just bought this for Minecraft. Will it be ok?
GavTha
CORSAIR iCUE 465X RGB GAMING CASE
Intel® Core™ i5 Six Core Processor i5-10600K (4.1 GHz) 12 MB Cache
ASUS® PRIME B560-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
16GB Corsair VENGEANCE RGB PRO DDR4 3600MHz (2 x 8GB)
8GB NVIDIA GEFORCE RTX 3070 - HDMI, DP, LHR
1TB CORSAIR FORCE MP600 NVMe PCIe M.2 SSD (up to 4950 MB/R, 4000 MB/W)
PCS FrostFlow 120 Series ARGB High Performance Liquid Cooler
2 PORT (1 x TYPE A, 1 x TYPE C) USB 3.1 PCI-E CARD + STANDARD USB PORTS
Windows 11 Home 64 Bit
Alltruism
What sort of monitor (resolution / refresh rate) will you be using with it? Is it mainly just vanilla Minecraft you'll be using it for, or Minecraft with RTX or shader mods etc? What budget do you have?
The Intel CPU you've picked is 10th gen, so quite long in the tooth now 12th gen is out (and 12th gen is getting very good reviews compared to the previous ones so may be worth considering if it's within your budget). 120mm AIO coolers aren't ideal so may be worth looking at 240mm or above.
GavTha
Thanks. My son will be using RTX Shaders and is getting a 27 inch 1080 monitor refreshing at 144Hz.
Is the problem with the 120 the noise?
sck451
As @Alltruism says, you can do much better for your money. Here's something about £50 cheaper that would be significantly better than that build for the long term. To do either this or your original build justice, you should get a 1440p 144Hz display, rather than a 1080p one. Particularly at 27", the quality just won't be very good.
Intel® Core™ i5 10-Core Processor i5-12600KF (3.7GHz) 20MB Cache
ASUS® TUF GAMING B660-PLUS WIFI D4: ATX, LGA1700, USB 3.2, SATA 6GBs - ARGB Ready
512GB INTEL® 670p M.2 NVMe PCIe SSD (up to 3000MB/sR, 1600MB/sW)
512GB PCS PCIe M.2 SSD (2200 MB/R, 1500 MB/W)
Windows 11 Home 64 Bit - inc. Single Licence [KK3-00027]
Microsoft® Edge
Price: £1,623.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/3N0pzx2hJt/
