Two days ago I have built my first pc, And everything was all good, installed windows 8.1 Pro , installed most of things i need (Used it for a good 2 hrs or so) but then it suddenly switches off automatically, without any noises or anything, I tried booting it up again afterwards, and it turns off again after 15mins, then I waited for half an hr and tried it again and the same things happens. I've checked the Event viewer and this Kernel Power Error popped up. I've also checked if i need to update my BIOs but the other option than the one I already have on the site is in Beta therefore it shouldn't be the BIOs problem.
Here are my specs:
CPU:AMD (Piledriver) FX-6300 3.5GHz(4.10GHz Turbo) Socket AM3+ 6-Core Processor - Retail
Motherboard: Gigabyte GA-970A-UD3P AMD Socket AM3+ Motherboard
GPU: Sapphire Radeon R9 270X Dual-X Boost OC AMD Graphics Card 2GB
Memory: 8GB (2x4GB) Crucial Ballistix Sprot 1600MHz CL9 DDR3 Dual channel kit
HDD: 1TB Seagate Barracuda ST1000DM003 3.5"SATA III Hard Drive
PSU: EVGA 500W 80 plus power supply (100-W1-0500-KR)
DVD Drive: LiteOn 24x Internal SATA DVD RW Drive
Any Ideas what the problem is?
Here are my specs:
