You'd need to do it. It's software.Will I be able to do it myself or is this something PCS would need to do?
Thank you very much! Probably a stupid question, but is it safe for me to do this? Will that delete any of my information that I currently have on my PC (like installed applications, files etc)?clean install instructions:
Download a new copy of Windows using the Media Creation Tool to an 8GB (min) USB.
Boot that USB and choose a Custom Install.
Delete all UEFI partitions on the system drive (EFI System, Recovery, MSR Reserved, Primary).
Select the unallocated space that results and click the Next button. The installer will create the correct partitions and install Windows.
Run Windows Update repeatedly, even across reboots, until no more updates are found.
You may need/want to download and install the latest graphics driver from the Nvidia/AMD website (they change so regularly the latest version isn't always in the Windows libraries).
It will delete everything and reinstall your OS from scratch.Thank you very much! Probably a stupid question, but is it safe for me to do this? Will that delete any of my information that I currently have on my PC (like installed applications, files etc)?
Nasty virus?I don't think it will, there's something at the OS level forcing through the flash. I think you need to clean install.
very nastyNasty virus?
Yeah, that's what I'm thinkingNasty virus?
