Laptop keyboard light problem
Hi, Guys! Im two week your new customer :)
owner ''15.6" VYPER III'' model
i have little problem with my laptop keyboard light:
Now if i press hotkey combination for k-light(On/Off) - Nothing happens...
(everything was fine before)
Maybe anyone know how to fix this?
or maybe i need some special driver for that?
(Win10)
no idea...
thanks for the help! ;)
steaky360
Check your PCS page to see if there are any drivers in there which might help they usually have all the relevant drivers online for you if needed.
(Win10)
no idea...
Everything was fine before what?
It's was first what i searching before create this topic...
I was search all PCS page couldn't found any section where have similar section like PCS software.
- Can you share a link (if that section exist) or explain for me where to look properly?
Thanks!
Seriously, it was a joke or not? (i don't have time for joke)
Apologize if you did not understand me!
i will explain, what i mean: ''Everything was fine before'' - that function was working like should - now not.
Postscript: I hope this helps to understand.
The point is, before what? What changed? Did you install some software, was there a windows update? We need more information.
1. Buy new laptop from you two week ago (owner ''15.6" VYPER III'' model)
2. Checking all work good
3. Reinstall official windows pro 10 latest version, done official license activation, udate latest version windows all software.
4. Start enjoy my new laptop
5. After 2-4 days i was need to use laptop in dark place and find out my keyboard light doesn't work.
- Now if i press hotkey combination for keyboard light (Fn+F6 or F7) Nothing happens like that command combination doesn't exist.
- i was tried all rest special combination (Fn+ F1,2,3,4,5....) just for checking they all work like should, but keyboard light not.
- checking ''Device Manager'' there don't have any issue show all fine.
6. Start think, maybe you have some special driver for that keyboard? (like PCS software)
- But! I was search all your PCS page couldn't found any section where have similar section like some ''PCS software'' or ''PCS drivers pack''.
if you know where find Can you share a link (if that section exist)
that why i ask for help:
Maybe anyone know how to fix this? or maybe somebody was the same problem?
(or the worst part can by keyboard LED - are dead... but i don't think so)
When you reinstalled windows did you install gaming center?
Hello, Yes! Right! Thanks! exactly what I needed!
One friend told to me how I can find all Drivers what I need.
Just for the future if somebody has the same problem you can find all Drivers on: Login in your account/Find TECH SUPPORT/Download
(You cant see this section on the PC website, until you Login!)
this is the answer, what I was looking for here...
Thanks.
