greatchris
Hello,
So I've had my laptop for a while now and its all been running smoothly, well after the whole overheating problems it suffered from at the start but sent it back and the nice people at pcspecialist fixed it .
But now I'm having some strange problems with the power supply and charging it while its turned on. Basically I'll plug it in and for a few seconds windows will register it as charging, then after a bit it will stop registering it as charging and all the LEDs start blinking at me. I can just take it out and plug it back it and that seems to make it charge again but eventually it decides to just start blinking at me again.
I've changed the power plan to power saver and that seems to have improved it but it still happened while I was typing this. It seems to charge fine when turned off. I've currently got a mouse and a cooling stand plugged into the USB's and they pretty much always are. I've never noticed it had this problem until today.
Also not sure if you need it but I've learnt that its normally best to provide as much info as possible when reporting problems so I use the laptop mainly for the internet but I do occasionally play games on it(left for dead, portal 2, neverwinter nights 2 online, morrowind) and I've never had any problems running them.
The specs for it are below:
Chassis & Display Enigma III 540: 15.6" Matte HD LED Widescreen (1366x768)
Processor (CPU) Intel® Core™i5 Dual Core Mobile Processor i5-2450M (2.50GHz) 3MB
Memory (RAM) 8GB SAMSUNG 1333MHz SODIMM DDR3 MEMORY (2 x 4GB)
Graphics Card nVIDIA® GeForce® GT 540M - 2GB DDR3 Video RAM - DirectX® 11
Memory 1st Hard Disk 500GB SEAGATE MOMENTUS, SATA 3 Gb/s, 16MB CACHE (7200 rpm)
1st DVD/BLU-RAY Drive 8x SATA DVD±R/RW/Dual Layer (+ 24x CD-RW)
Memory Card Reader Integrated 3 in 1 Memory Card Reader (SD, MMC, MS)
Sound Card Intel 2 Channel High Definition Audio + MIC/Headphone Jack
Network Facilities GIGABIT LAN & KILLER™ 1102 WIRELESS GAMING 802.11N NETWORK CARD
USB Options 1 x USB 3.0 PORT + 2 x USB 2.0 PORTS AS STANDARD
Battery Enigma III Series 6 Cell Lithium Ion Battery (5,100/5,200 mAh)
Power Lead & Adaptor 1 x UK Power Lead & 120W AC Adaptor
