Hello,
I recently returned from University to open up my old laptop which I've had for about 1 - 2 years now. I haven't used it in a couple of months and when I returned home, I started it up and everything was running fine. After about 15 minutes the power was drained on it and the screen turned off and I had an orange battery light flashing. So I got the charger and plugged it in. After about 30 seconds of use once the charger was plugged in all of a sudden the screen cut out, noise from the laptop stopped and everything turned off.
I played around with it, trying to get it to turn back on and it didn't work at all. I thought it may be the power pack as even when the charger was plugged in no lights lit up on the laptop. I then tried a different charger (not the power pack, but the plug to power pack bit) and still nothing. I finally looked in to some troubleshooting via my phone and discovered that a common problem in laptops cutting out and not turning back on can be solved by a certain method of taking the battery out, unplugging it and holding down the on button for 30 seconds. then replugging it back in and trying again (yes I did do it without putting the battery back in) and yet still to no avail, the laptop won't turn back on.
Has anyone got any quick fixes or know what is wrong with it, I don't have the money at the current time to send it anywhere to get it checked out..
Any help is much appreciated.
Thank you.
Thank you.
