That is fast I'm so jealousSo, i just pulled the trigger with the 36 months assurance
(just in case, because price XD)
I'll do a review when i'll have the laptop.
Damn, that's a shame. Does seem to happen on some of these TongFangs as the screen surrounds are glued rather than clip in. Definitely best to send it in now as you say.I have to send back my recoil for a little problem with the edge of my screen, that come off, just over the top of the left hinge.
Nothing too bad, but i think it has to be taken care before it's too late.
Is it a Clevo? I get confused so often these days. Mid life crisis and allIt's a clevo thought
And to be fair, i think that the hinge may be too tight (in comparison with my sis destians)
Ah, that's why I'm getting confused!Well, the 15" recoil was a tongfang abd the 17" recoil was a clevo
Yeah, why do things simple when you can do it the hard way XD
(It sound better in french ^^")
Are you sure they're dead pixels and not stuck pixels? What tests have you done?And i have more or less a ten of dead pixel on my new screen ... (that i paid to be installed during the rma)
i ...
i don't really know what to say ... it been less than a week i have it back ...
I know that this is murphy's law, bad luck, or wathever, but ...
i'm kinda sad about this ...
especially because i don't know if this will be taken in charge by PCS (because i don't have the dead pixel warranty with this screen) and because if it will (i wish), i'll have to send it back to the workshop, again ...
I ...
Well, i'm kinda depressed about this ...
Yeah, that's pretty conclusive then, that's really bad!i looked a this page :
5 Ways to Fix a Stuck Pixel on Your Screen
A dead or stuck pixel on your screen can be annoying. Here are the best ways to test your screen and how to fix dead pixels.www.makeuseof.com
and i ran jsscreenfix for 30/45 minutes
I sincerely hope it doesn't take too long, I would have thought they'd treat is as a priority given it was a result after a previous fix.To do a little bit of follow up :
My laptop is back for a new rma, i just hope everything will be allright ^^
(the french pcs spokeperson was fantastic, really, he really is worthy of every compliment i can find ^^)
