laptop wifi card antenna connection wanted!
Music Guy123
Ok, I know this sounds a little weird but I was wondering whether anyone has an old laptop that they won't be using the wifi card for anymore. When you open the laptop (normally very easy to access the wifi card) you will see a black wire and a white wire leaving the card. They have snap-on connectors. Ideally, I would like 2 connectors with as much of the wire as you can possibly get. Any help will be appreciated, I know this sounds different!
Music Guy
Wozza63
Biblical Poster
ive got a few various wireless cards, dont know if they work, but i doubt id be able to get the cable with it
Music Guy123
What cards are they? It needs to be a laptop pci card. It is the white and black cables that I am really looking for.
Wozza63
Biblical Poster
i wouldnt have a clue, i just took the actual card out of old laptops i threw away, only one left with cables is the one in my current laptop, which id like to keep
Wozza63
Biblical Poster
yeh well, i just took them apart to try and gain a bit of experience just so i knew about more when going into my new computer
vanthus
Member Resting in Peace
If your still looking for these music guy I can send them down to you,
you can have the card as well if you want.
