LED strip Question, pics included.
scarpa1
So I have a LED strip in my Liquid Series build. This is the only RGB I can not control via software (Armory Crate) as its plugged into the PSU.
I guess PCS did this as its a UV Led strip and I have the UV clear blue liquid so perhaps they thought I would always have it on.
Its not a problem not being able to turn it off but if I wanted to be able to turn it on or off via software what should I do?
Seems its connected to the PSU via an adapter which seems a very overkill one, I'm sure its not got anything else connected to it but not 100% sure so Ive attached some pics.
My full specs aren't copying properly, seems to be copying my original order and not all the changes I made.
Its the Lian Li O11 Dynamic XL case
with a Strix X570-F MB and just the one 50cm LED UV strip, 4 holes on the connecter.
First pic shows the LED strip connector which looks to be the only thing connected to the adapter thing which then goes to the PSU
