Looking for help on a build for the misses to get into gaming
Theshygamerguy
Need help with making a build for a decent entry level gaming pc than can run most games at a decent level all suggestion and help welcome
She loves the colour pink if that makes s difference when it comes to parts ?
What is your budget?
Does that have to include keyboard and monitor? If not then what monitor will she be using (it affects the GPU choice)?
What sorts of games will she be playing?
How upgradeable does it have to be?
Theshygamerguy
What is your budget? She's looking at just the computer alone for possibly below £1000 or below If that's not possible then ill talk to her about bumping the budget.
She is looking into then quartz Razer set up as that's what she likes the look of due to it being pink 😂 haven't yet decided on a monitor so if you could include a monitor as separate from the budget so we have an idea of what to look for :) doesn't have to be anything crazy just so she can happily play at a good gaming experience
What sorts of games will she be playing? Atm she's playing Phasmophobia/planet zoo/World of warcraft/sims/among us/
Ideally would be better if it was able to be upgraded as its her first pc so would need to last .
£1000 for the tower is 1080p and will need around £150-£200 spent on a monitor.
If you wanted to break into 1440p (which would make a big difference visually) then you would be looking around £1200 (Once the 3060Ti is released) and you will need to spend around £300 on a monitor.
The overall budget needs to be considered as everything goes hand in hand :)
Theshygamerguy
She currently plays on my pc set up which is 1440p :) I currently have a zotac gaming geforce rtx 2070
I would probably be looking to upgrade to the new graphics cards wondering ..if she went for a 1440p tower if she took my graphics card from my current one would that work. Sorry if that sounds complicated.
Theshygamerguy
You could slot the GPU into this and it would be fine..it would also be ready for any GPU upgrade in future. Slightly more than the budget...the case and cooler were selected as they have RGB lighting which should, hopefully, allow Pink as a colour choice which should keep her happy (not 100% sure pink is a selectable colour on them but I don't see why not):
CORSAIR iCUE 465X RGB GAMING CASE
Price: £1,084.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/E4DFZdS25k/
I have currently the 8GB NVIDIA GEFORCE RTX 2070 SUPER that I would be looking to slot in would that go with all this and would that effect the warranty?
Gavras
Master Poster
Lol be very careful here.
You may find yourself evicted from your PC, especially if you have ‘budget PC ’ selling point for her lol.
as you said, keeping the experience the same is best bet.
been Through it with cars, that was fun lol.
Theshygamerguy
Unique URL to
Also sorry to be a pain shes looking at a all white and pink theme ideally :)
The only way to get that kind of customisation would be to build your own.
There's only one white case on PCS which is the NZXT H511, which is an ok case actually, it's not bad.
I guess the best you could achieve would be to have that case and then you could set all the RGB within to as close to pink as you could get it.
Theshygamerguy
Well, there's only one White case PCS offer, the NZXT H511 but it's not the best case around for cooling. Alternatively, you could find a different white case elsewhere and have it sent in for PCS to build into. I did have a look around the internet for a pink case but they were either poor airflow ones (or looked like having poor airflow) or way too expensive for the budget
Great thanks for the help :)
scarpa1
There is another white case, a Thermaltake one.
Bit of a beast though, might need a separate desk just for the case and maybe just for custom water cooling, not sure.
Looks nice though.
Theshygamerguy
Awesome thankyou
Just checked on my H100i RGB Platinum, you can get a lovely shade of pink. I mean... if you're into that kind of thing... I definitely won't be keeping it that way...
😂 pink isn't for me 😂 its for the misses
