Maximum Dimensions for a GPU in a case? | PCSPECIALIST
Marin
Hi, I've got a PCS Cyclone gaming case and I was just doing some pre-planning for a potential upgrade for GPU (among other things). My current GPU is a Zotac GTX 1080. I was just wondering if I could fit a Geforce 20 or 30 series GPU into the case without it being too big. My current GPU is 300mm x 148mm but I know different cards can have different dimensions and I want to make sure I get the right one. Thanks in advance.
steaky360
The 30xx cards will probably fit in assuming your dimensions are correct (for example the Founders 3080 is reportedly 285mm x 112mm) - but to be sure you'd need to consider what card you're looking to get and compare its dimensions as non founders cards WILL be different sizes.
Recluse
Don’t forget, the primary factor in a GPU upgrade aside from physical size is if the PSU has enough headroom.
Marin
I've got a Corsair VS450, and I think I've got a lot of leeway for an ATX type PSU for about 850W, maybe more if I wanted. Power consumption I think was 433W so I will definitely need to upgrade PSU if I'm going to upgrade GPU.
Recluse
Yes, you’d need 850w as a long term investment and preferably a RMx model, but TXm as an absolute minimum.
