yes indeed! that's what i said, the computer is the same configuration, only the gpu, ram and drive changed.That’s not the specs from your order page, we need to know the full order details.
But that's not the full specs, that's only about half of the configuration, we need to know the full specs.yes indeed! that's what i said, the computer is the same configuration, only the gpu, ram and drive changed.
and what are the full specs that are missing? just what could possibly make a laptop more than these components?But that's not the full specs, that's only about half of the configuration, we need to know the full specs.
Ok, if you're unable to provide the order specs, we have to take it that you didn't order this unit from PCS. That's all I was trying to verify.and what are the full specs that are missing? just what could possibly make a laptop more than these components?
thank you! looks like there is no advice to be found anywayOk, if you're unable to provide the order specs, we have to take it that you didn't order this unit from PCS. That's all I was trying to verify.
You're fully entitled for advice on peripherals or software, but we won't be able to advise on any hardware issue, just making you aware of that.
You have had lots of advice from 2 sources.thank you! looks like there is no advice to be found anyway
honestly i've been waiting two days for some advice and only had a wiff of it.
yes but why?
are there more important components than gpu and cpu?
