Monitor arms
I'm after a half decent monitor arm for my Asus 27insch PG279Q.
Any suggestions
I will always suggest these, they're expensive than others, but they have a much higher weight rating, are modular so you can amend them if you move to multi monitors or a different sized monitor down the line, and I've found them incredibly reliable for a long time now. I've had a single 27" monitor and dual 27" and 28" monitors by just swapping out the monitor arm.
You get the choice of mounting solution as well, either drill into desk which I have as I have a very cheap IKEA desk that I didn't mind doing so, or a clamp which is likely more suitable.
That screen is VESA 100 x 100, so you just need to make sure the mount supports that.
closetchimp
They look really good, just a shame most are out of stock at mo, but that's obviously a sign that they are in demand and decent quality.
They do have the double arm but I only want the single so I'll keep an eye on these and look at getting them when back in stock.
Cheers ears.
