Monitor for RTX 3090 system
I would like to know what people think of this:
before the new high refresh rate 4k screens people were using 4k 60hz and were I assume perfectly happy playing games including fps on such screens. So if I get a 4k 60hz monitor then it should be ok for games generally (as a stop gap) even if not as good for frame rates as a 1440p 144hz monitor? I dont play highly competitive games but would like to experience the FPS in Elite Dangerous Odyseey and a few other titles. Will my experience be a bad one at 60hz refresh or will it be acceptably fine just as it has been for other gamers for several years since 4k came out? Because if it is ok then I would prefer 4k to 1440p and this would answer my question as to wehter to go 1440p 144hz or 4k 60hz. My 3090 would be under-utilised but I have to accept this until I can get my hands on a 4k high refresh rate monitor.
As already said, for gaming 1440p 144hz would be a far better experience than 4k 60hz
60hz is not “gaming”.
I got bored of posting links. 60hz “gaming” monitors are purely for early adopters who buy it just to try out a new resolution as soon as it’s released. You’d never use a 60hz monitor as your primary gaming monitor though, it’s really poor vs high refresh.
NoddyPirate
Grand Master
Thanks for the links all the same Spyder - good info for me for the future whenever I get around to considering a monitor/GPU upgrade. (y)
Just to explain the reason I'm asking the above, I'm not trying to sound obsequeous, there is a reason for it, it may be that you don't realise the possiblities and expectations with modern gaming monitors.
It's like TV's, above a certain size, the expectation isn't that you have it on the stand on the desk, it takes up far too much space on the desk and isn't practical.
Like with TV's, it would be expected to either wall mount it, or use a desk bracket on which you mount it.
There are loads of different options, and various different mounting methods if it's a desk mount.
I have for instance a desk mount which is drilled into the desk, but you can get clamp ones also. Wall mounts are just like any TV mount.
I'm gonna definitely get grilled about dust again :eek:
ChristopherH
Can anyone please confirm that my gtx 670 dp is 1.2 but my monitor will be dp1.4 meaning I cannot use the monitor on dp to test it when I get it in advance of my new PC? I guess I can use hdmi just to get it working. Graphics card hdmi 1.4 new monitor will be monitor hdmi 2.0
You can use a DP 1.2 on any monitor that has that or above. It's just you won't get the benefits of 1.4 that the monitor supports.
Same works with HDMI or any output.
HDMI is years behind DP though, so if using anything, you want to use DP.
ChristopherH
Yes PC now ordered. But it was from a supplier. Got a fantastic deal. And get it end of June which for a rtx 3090 system is pretty quick atm. PCSpecialist wait time was 3 months and price was more expensive for pretty much the same spec. But they were my preferred supplier just cant wait that long.
