Monitor help | PCSPECIALIST
Monitor help
BizzHood
Hi totally new to the pc world wondered if anyone could point me in the right direction for a monitor based on my build.
I hope im able to game in 1440p but have no clue what my fps would be for most games thats why I'm stuck on choosing a monitor and dont want to over do it or under do it. Thanks in advance!!
CasePCS P209 RGB MID TOWER CASE
Change to: CORSAIR 275R AIRFLOW TEMPERED GLASS GAMING CASE
Processor (CPU)Intel® Core™ i9 Ten-Core Processor i9-10850K (3.6GHz) 20MB Cache
MotherboardASUS® ROG STRIX Z490-F GAMING (LGA1200, USB 3.2, CrossFireX/SLI) - ARGB Ready
Memory (RAM)32GB Corsair VENGEANCE DDR4 3200MHz (2 x 16GB)
Graphics Card10GB NVIDIA GEFORCE RTX 3080
1st Storage DriveNOT REQUIRED
1st M.2 SSD Drive1TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 750W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingCorsair H100i RGB PLATINUM Hydro Series High Performance CPU Cooler
Wireless/Wired NetworkingWIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
BizzHood
T^T Wish I could get the g9 but it is always out of stock, so i just bought the g7. I'll use that for a year and maybe swap after.
Thanks for the helpful post !
I was looking at the g7 seen mixed reviews, how does it perform for yourself. Thanks in advance
D
Deleted member 103489
Guest
I am currently usingsamsung g9 odyssey and it's dream to have in so many levels.. This would be perfect match for the 3080 build.
BizzHood
I am currently using samsung G9 monitor and it's dream to have in so many levels.. This would be perfect match for the 3080 build.
Yeah unfortunately thats out of budget at the moment due to how much I spent on the pc itself, leaving towards the g7 for now as I guess it would be the next best option but wasn't sure if it was overkill.
Babychino yolk
Yeah man, the g7 is a beast. Bigger in size than i thought, the 32 inch g7 has been a luxury for me so far, its so fast and my games feel so fluid while playing.
Slight flickering during load screens in some games but absolutely nothing is displaying while I'm gaming so I'm not affected at all by it.
