Laptop Specs:
Chassis & Display
Recoil Series: 17.3" Matte Full HD 300Hz 72% NTSC LED Widescreen (1920x1080) + G-Sync
Changed to: Recoil Series: 17.3" Matte QHD 165Hz 100% sRGB LED Widescreen (2560x1440) + G-Sync
Intel® Core™ i9 Eight-Core Processor i9-11900K (3.5GHz) 16MB Cache
32GB Corsair 2933MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® RTX 3080 - 16.0GB GDDR6 Video RAM - DirectX® 12.1
250GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 2300MB/W)
AC Adaptor
2 x 280W AC Adaptor
2 x 1 Metre UK Power Cable (Kettle Lead)
Battery
Recoil Series Detachable 8 Cell Lithium Ion Battery (97WH)
2 Channel High Def. Audio + SoundBlaster™ Atlas & Super X-Fi
2 x THUNDERBOLT 4 + 1 x USB 3.2 (TYPE C) + 3 x USB 3.2
Hello, I'm having a bit of an issue with my CPU temps and i'm hoping someone has some answers. When i download/install a game on steam for example or a windows update the temp jumps to 80+ degrees before the fan revs up and gets it down to 65-70+ while its working. When i play a game on the other hand,Grounded for example,it jumps to 90 degrees and stays around that even with the fan going nuts(i have a cooler under the laptop as well). I'm playing that game on epic setting and the rtx3080 is laughing at it with 60 degrees. So why is the CPU temp going so high when the GPU isn't even bothered on graphics like that? I've installed HWinfo64 and Aida64 in hopes that they would show something i'm not seeing and they are showing the CPU clock speed hovering around 4788mhz constantly when not doing much and 4688mhz while in Grounded... That is very wierd to me... Shouldn't it stay around its stock clock speed? since as far as i know it's not overclocked.
Had to send it back for repairs almost 3 weeks ago cause it had an instant shutdown while i was playing and didn't want to power up again,got it back today 27.10 with a fresh copy of windows so i made sure to install everything needed(all pcspecialist drivers and windows updates). Before the incident it had the same problem with the cpu temp (surprised it didn't get picked up on the stress tests) and i found a way around it with a registry change on the intelppm.sys while trying to fix a bsod (was missing a driver,fixed it),the cpu temp stayed around 70 degrees with the registry change while playing games and even less when downloading so i kept the change,didn't affect performance or anything. I know the i9 is supposed to run a bit hot but 90 degrees seems a bit much,especially for very long gaming sessions. I'm gonna wait to see if anyone has any ideea on what's going on and if there's anything to be done to fix this before i apply the registry change again and move on. Thank you in advance.
Chassis & Display
AC Adaptor
2 x 280W AC Adaptor
Battery
