My first upgrade in many years please review
weare one
Hi all
First time posting and after lots of searching I have decided on PC Specialist for my new upgrade system.
Now I am not a gamer so most of you will hopefully say this is overkill but certainly a few years future proofing has been built in.
My normal use for this system will be the following all running at same time
Photoshop.
Word, between 2 and 6 docs always open.
Excel spreadsheet.
Firefox, at least 6 if not more tabs always open
Thunderbird for emails.
Any and all suggestions will be much appreciated.
COOLERMASTER K350 GAMING CASE
AMD Ryzen 7 1700 Eight Core CPU (3.0GHz-3.7GHz/20MB CACHE/AM4)
ASUS® PRIME B350-PLUS (DDR4, 6Gb/s, CrossFireX) - RGB Ready!
8GB Corsair VENGEANCE DDR4 2133MHz (2 x 4GB)
6GB NVIDIA GEFORCE GTX 1060 - DVI, HDMI, 3 x DP - GeForce GTX VR Ready!
FREE Rocket League with select GTX 10 Series GPUs!
1st Hard Disk
250GB Samsung 850 2.5" EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
2nd Hard Disk
2TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 64MB CACHE
DVD/BLU-RAY Drive
Corsair H60 Hydro Series High Performance CPU Cooler
LED Lighting
2x 50cm Blue LED Strip
Extra Case Fans
WIRELESS 802.11 AC1200 867Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD
Genuine Windows 10 Home 64 Bit - inc DVD & Licence
NO OFFICE SOFTWARE
Firefox™
Monitor
IIYAMA X2783HSU-B1 27" AMVA+ LED WIDESCREEN, 1920x1080
Keyboard & Mouse
LOGITECH® MK270 WIRELESS KEYBOARD & MOUSE COMBO
Total Order Price £1,476.00
When you say you're not a gamer, do you mean you won't be gaming at all?
If so you could ditch the GTX 1060 in favour of one of the cheaper GPUs. I'm not sure how much photoshop would benefit from a 1060 over a 1050 ti.
https://www.pugetsystems.com/labs/articles/Photoshop-CC-2017-NVIDIA-GeForce-GPU-Performance-899
Photoshop.
Excel spreadsheet.
16gb RAM might be useful there.
You'd probably be better off with an external one, since the internal one seems to be USB 2 only. You could get external ones more or less anywhere you like if you need formats not supported by the one PCS sell. Also the cases like the K350 that do have space for an internal one tend not to be ideal in terms of the performance and features they offer for the price.
1st Hard Disk
Your mobo has an M.2 slot which would allow for the much faster but similarly priced PM961.
An Intel build would give higher performance in photoshop, and general office tasks and would in fact cost pretty well the same:
https://www.pugetsystems.com/labs/a...-2017-AMD-Ryzen-7-1700X-1800X-Performance-907
Your build above with an in i7 7700k and Z270H mobo but the same other bits: https://www.pcspecialist.co.uk/saved-configurations/intel-z270-pc/8BsCkSCCRR/- £1480
Something like this may be a bit more balanced:
CORSAIR CARBIDE SERIES™ 200R COMPACT GAMING CASE
Intel® Core™i7 Quad Core Processor i7-7700k (4.2GHz) 8MB Cache
ASUS® ROG STRIX Z270H GAMING: ATX, LG1151, USB 3.1, SATA 6GBs
4GB NVIDIA GEFORCE GTX 1050 Ti - DVI, HDMI, DP
1[SUP]st[/SUP] Hard Disk
M.2 SSD Drive
256GB SAMSUNG PM961 M.2, PCIe NVMe (up to 2800MB/R, 1100MB/W)
DVD/BLU-RAY Drive
Noctua NH-U14S Ultra Quiet Performance CPU Cooler
Monitor
Keyboard & Mouse
Quantity
1
Price £1,448.00 including VAT and delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/intel-z270-pc/Bbd9Q2C4bE/
It's mostly the tweaks above, trading in the 1060 for a 1050 ti and 16gb RAM.
The Noctua cooler is better and cheaper than the H60. PCS aren't selling the Noctua cooler with Ryzen builds at the moment, but if going with an Intel build you might as well. Most cases don't fit the Noctua - the Corsair 200R is the cheapest that does (and is a decent enough case). I ditched the blue LEDs since it doesn't have a side window.
If you want a Window sand blue LEDs you can always get a case like the Fractal Define S has one, is large enough for the Noctua, and is an excellent case anyway (plus an external DVD drive if you need a DVD drive)
weare one
Hi Oussebon
Thank you very much for your detailed reply; you have certainly given me lots to think about.
Correct I will not be playing games at all.
GPUs…..I did actually wonder if Photoshop would benefit much
Ram…..My bad I actually downgraded form 16gb to 8gb thinking the hyper threading of the Ryzen would compensate.
Memory Card Reader…..thanks for the tip
Hard Disk…..never had a M.2 so will look into it
i7 7700k…..I was considering this before Ryzen came out and again I thought hyper threading was the way to go
Processor Cooling…..Expert advice much appreciated
Case/DVD drive…..The one thing that I am auld fashioned about…I like an internal DVD drive…..will re-think
Once again thank you very much for your advice and links, I’m so glad I had the foresight to post here :rockon:
weare one
Hi Oussebon
When I click your link I get
£1,508.00 inc. VAT
not a great deal but I’m struggling to work out what parts are different.
M.2 SSD Drive
DVD/BLU-RAY Drive
Monitor
Keyboard & Mouse
Quantity
1
The i7 and Ryzen both have hyperthreading. Well, Intel's version is called hyperthreading (HT), AMD Ryzen's is called Simultaneous Multithreading (SMT). What the R7 has is twice as many cores (and therefore threads). Which is a huge advantage for things that use a lot of cores and threads, or for things that are pretty demanding on a small number of threads if you want to run loads of them together e.g. virtual machines. But, from what you said, that doesn't apply to you. :)
Photoshop is relatively lightly threaded and gradually opening more and more browser tabs will eat your RAM more than your CPU. Besides which 6 tabs isn't all that much. I'll often have 20-50 open in IE and Chrome (as might many people) and that's not a problem.
The 200R in the spec above is fine if you want a perfectly respectable case with an internal dvd drive. it just doesn't have a side window. If you want a case with a side window for LED lighting and room for the Noctua cooler then the CM690 III is the cheapest one that fits the bill.
That said you don't need the Noctua by any stretch of the imagination. The CM212x would be more than sufficient and should fit into pretty much every case.
£1,508.00 inc. VAT
Curious. I opened the link in another browser with a clean internet history and it still came out £1448.
Are you getting it delivered to the ROI? If so, the extra delivery and higher VAT there seems to take the price to £1508.
In which case that would make the spec I drew up £32 more expensive than what you originally had. You could drop the cooler down to the CM212x which would reduce the cost by £31. And drop the case to something like the Corsair Spec 03 for another £14 savings.
You might like to add the silver warranty upgrade for an extra 11 months of carriage costs cover.
weare one
Great advice all round Oussebon thank you very much :rockon:
And I really appreciate the time that it must have taken you for all the info and links :punk:
