My PC has stopped connecting to TV monitor
SamE
I had a PC for Christmas which has worked really well for gaming. About 1 hour ago the PC signal to the tv was lost. I tried my X box through the HD cable and this works fine. The PC is on and lit as normal but doesn't appear to be sending anything at all to the TV. Can anyone help / advise please? Sam.
The PC is as follows:
Case PCS ENIGMA 6003B BLACK CASE
Intel® Core™i5 Quad Core Processor i5-6400 (2.7GHz) 6MB Cache
ASUS® H110M-R: Micro-ATX, DDR4, LG1151, USB 3.0, SATA 6GBs
8GB HyperX FURY DDR4 2133MHz (2 x 4GB)
4GB NVIDIA GEFORCE GTX 1050 Ti - DVI, HDMI, DP
1st Hard Disk
1TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 32MB CACHE
1st DVD/BLU-RAY Drive
CORSAIR 350W VS SERIES™ VS-350 POWER SUPPLY
INTEL STANDARD CPU COOLER
LED Lighting
50cm Red LED Strip
MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT
PORTS
Genuine Windows 10 Home 64 Bit - inc DVD & Licence
DVD Recovery Media
Windows 10 (64-bit) Home DVD with paper sleeve
mantadog
Superhero Level Poster
Is it only connected via the TV, no stand alone monitors? Do you have any way of checking it on another monitor/TV with the same cables/ports on the GPU?
It might sound stupid, but have you tried restarting the computer?
Other than that, have you got any other options for connecting to the same TV like VGA ports or display ports? You could also try plugging directly into the motherboard and using the onboard graphics to see if that solves the issue, if it does the GPU may have had an issue.
SamE
I have tried other TV and the same. I have also restarted PC several times but to no avail. I will purchase a VGA cable in order to see if that works. Thanks
Rakk
The Awesome
Do note that your graphics card only has DVI, HDMI and DP ports before buying any new cables so make sure you get one that will fit - depending what ports your TV has you may need also need an adaptor.
