need brtacket for 5.25 inch bay
hi
i need the coolmaster cosmos c700p
case bracket
that will allow me to have an additional 5.25 bay
on the coolmaster c700p
i want to use a 4k blu ray wrier
and a sentry mix 2 fan controller
i need the full name of the bracket with full instructions how to fit
and where to buy it from
thanks
So this case has 1 5.25" drive bay.
I don't think many people actually "need" a c700p case. Many people might "want" a c700p case. But if you "need" 2 5.25" drive bays then maybe what you "need" is a different case. :)
These are the spare parts Cooler Master sell for the c700p
https://www.cmstore.eu/categories/spare-parts/case/cosmos/cosmos-c700p.html
Actually I've taken another look at this. It seems you can fit a 2nd 5.25" bay with brackets that come included with the case (so you don't need to buy anything). However the front fan mounting bracket is in the way, so it looks like you couldn't have 2 DVD drives in there, because you couldn't reach the 2nd device. https://www.modders-inc.com/cooler-master-cosmos-c700p-case-review/3/
So I'm not really sure what the point of that is unless it's to mount a fan controller that you then control via software. Which the Sentry Mix 2 isn't.
I think your best solution is to buy a different case that just does what you want it to, or to control your fans another way.
