need help picking a new monitor
chrisblackford636
hi all i'm trying to find a new monitor the monitor i have at mo is ASUS ROG Swift PG278Q 27 inch Widescreen LED
i'm looking for a monitor
35 inch or biger
G-SYNC
144hz monitor or higher
res 2560 x 1440 or higher
1 ms response time
ports i need display port
my spec
Case COOLERMASTER COSMOS C700M TOWER GAMING CASE
Processor (CPU)Intel® Core™ i9 14 Core Processor i9-9940X (3.3GHz) 19.25MB Cache
MotherboardASUS® ROG RAMPAGE VI EXTREME ENCORE: DDR4, 6Gb/s, CrossFireX/SLI, WIFI - RGB Ready
Memory (RAM)32GB Corsair VENGEANCE DDR4 3600MHz (4 x 8GB)
Graphics Card11GB ASUS ROG STRIX GEFORCE RTX 2080 Ti - HDMI, DP
1st Storage Drive6TB SEAGATE IRONWOLF PRO 3.5", 7200 RPM 256MB CACHE
2nd Storage Drive6TB SEAGATE IRONWOLF PRO 3.5", 7200 RPM 256MB CACHE
1st M.2 SSD Drive1TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
2nd M.2 SSD Drive2TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
DVD/BLU-RAY Drive16x BLU-RAY WRITER DRIVE, 16x DVD ±R/±RW & SOFTWARE
Processor CoolingNoctua NH-U14S Ultra Quiet Performance CPU Cooler
Extra Case Fans5x Corsair LL120 RGB LED Fan + Controller Kit
Sound CardONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Wireless/Wired Networking10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED)
USB/Thunderbolt OptionsMIN. 2 x USB 3.0 & 6 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Operating SystemWindows 10 Home 64 Bit
i'm useing it for gaming hopeing it get it for less than £1000 but not sure if that be possable lol i was not looking for new monitor when got the pc
The PC isn't very well suited for gaming, that's a very weak processor unfortunately.
Anyway, a 1440p ultrawide would be a good fit, something like a
chrisblackford636
how so? not had any issue sept METAL GEAR RISING: REVENGEANCE
It’s not a suitable platform for gaming. As such the CPU has a very low frequency which will greatly reduce gaming performance over a chip like the 9900k.
Also I wouldn’t be happy with the cooler on that CPU.
