Need help to build laptop ideal for gaming/photo editing
Woolflock
Hi guys,
I'm looking to buy a gaming laptop - my top price would be €1600.
Gaming wise, I mainly play the Sims 4, and would like to be able to play rpgs too. Not worried about having ultra graphics, but do like them high. I also want a machine that will be good for photo editing - I do photography with a DSLR and use RAW files and would be ecstatic to have a machine that wouldn't lag when working on every single photo. I also want a minimum of 2TB storage.
I was looking at the Proteus VII but noticed that it only had an integrated Micro-SD memory card reader, and that other models around that price range were similar. Since I transfer my photos on the normal SD card, I'd need something to fit that.
I'd really appreciate any advice on the spec I'd need, or model suggestions.
Thank you in advance for any help!
I'll preface this by saying I am not a laptop person as most of my knowledge is desktops so will definitely need an opinion from someone else. Also, are you specifically looking at 15" screens? Need to know as I am just about to post a 17" screen spec. However, I would imagine something like this may be appropriate:
Chassis & Display
Optimus Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
AMD Ryzen™ 7 Eight Core Processor 4800H (2.9GHz, 4.2GHz Turbo)
32GB Corsair 2666MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® RTX 2060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
Integrated 3 in 1 Card Reader (Full Size SD / SDHC / SDXC)
AC Adaptor
1 x 180W AC Adaptor
Battery
Optimus Series Integrated 46WH Lithium Ion Battery
1 x USB 3.1 PORT (Type C) + 2 x USB 3.1 PORTS + 1 x USB 2.0 PORT
Keyboard Language
OPTIMUS SERIES RGB BACKLIT UK KEYBOARD
Keyboard & Mouse
Webcam
INTEGRATED 1MP HD WEBCAM
Chassis
TongFang GK7NR0R (6GB RTX-2060, R7-4800H, 144Hz, Blank KB)
Price: €1,562.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/optimusXI-pro-17/fsRJSC5u8t/
@SpyderTracks Could you offer an opinion here please as I'm not sure if the Optimus Pro is the best platform to build on.
For the budget and to fit the criteria, @Nursemorph build is great. i Don’t think you’d be able to squeeze in a more premium chassis at this budget.
