Need Help!
LuxxReno
Hi, I need help in picking parts for a build.
I want the build to be able to stream warzone gameplay and be playable off the pc at the same time with 144FPS constant.
I'm open to people linking a build theyve made which can do the above and would really appreciate any and all help.
thanks for looking
LuxxReno
PCS SPECTRUM RGB MID TOWER CASE
10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP
Corsair H80i V2 Hydro Cooler w/ PCS Ultra Quiet Fans
LED Lighting
50cm RGB LED Strip
Standard Build - Approximately 12 to 15 working days
LuxxReno
It depends:
What is your budget?
What level gaming are we looking at? 1080p? 1440p?
sorry for late reply, i posted specs i put together above, does this seem overkill ? or have i missed something, really need help. 144 fps min and 1080p streaming off same rig please
JUNI0R
LED Lighting
50cm RGB LED Strip
This is an INCREDIBLY high spec build. this is wayyy overkill for 1080p 144hz and we'll be able to save you a lot of money. Do you have a monitor already? if so what's the resolution AND refresh rate or make and model?
LuxxReno
yes i have monitors atm but will add the correct monitors once i buy a pc. i'm really struggling with the specs side of things but i am adamant on havent good fps and very good looking stream, what are you proposals? and thanks for the reply
LuxxReno
also MSI monitors as im console atm its only 75hz, will switch that out for 2x 165hz monitors or what ever is needed i guess
JUNI0R
This spec will comfortably handle 1440p and a 144hz monitor. A good monitor to pair with this would be the Samsung G5 for £300. If you're looking for 1080 144hz, the 3060 is coming out in a week, that'll comfortably handle 1080 144hz and will save you even more money
8GB NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP
Price: £1,694.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/mmEqEYjPer/
LuxxReno
thank you so much, would you suggest i wait for the newer gpu to become availble on here?
JUNI0R
It depends what you're looking for. If you only want 1080p 144hz, then yes. If you'd prefer 1440 144hz with the monitor I suggested, I'd go for this spec. I'd also wait for input from other users before buying as there are ways they might be able to improve on what I've suggested
LuxxReno
yes ive had another reply on a different thread i posted somehow, it's a little bit more expensive than the one you've suggested, would you mind if I posted it here for you to have a look at?
JUNI0R
I'd recommend keeping all your questions about spec to one thread. but yes, feel free to post it here
LuxxReno
CORSAIR iCUE 465X RGB GAMING CASE
Price: £1,966.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/neZNe5WqDs/
Main Tweaks -
Case and Cooling - Upgraded both this areas, are vital for long term performance (Plus that case and cooler make for great RGB)
GPU - 3080 is massive overkill for 1080p, even the 3060ti is a bit strong but given your budget and wanting performance it will be worth it (plus lack of Nvidia options atm)
Network card - This card will give you far better performance than previous selected.
Bullguard - Ditched, windows defender is better and free
Silver warrenty - No brainer for a fiver
Storage - Given you an M.2 drive for windows to run off. Will give you a massive performance boost in terms of speed.
With this build as well all you will need to do is upgrade the GPU in a few years time if you get a higher res monitor. Will give you 7/8 years life at least :)
JUNI0R
Main Tweaks -
This looks like a good build too. It’s more expensive but it will be a better machine. Only change I’d suggest is changing the PCS 512GB M.2 to 1TB. looking at the games you play, 1TB will give you a lot more fast storage for large file games (plus the 2TB hard drive for more general files like documents and images)
Also thought I’d note that you seem very rushed to get this PC. If that is the case I thought I’d warn you, due to Covid, wait times are long. The graphics card you have is currently on pre-order so it’s difficult to know when your PC will be built it could be 20 working days, it could be 40, no one really knows. This thread might give you an idea but there’s no way to get a guaranteed estimate
LuxxReno
im not rushed with a pc, i've been looking for over a year and havent been able to commit because i know nothing of pcs hahah but these forums on here have helped alot. thank you for help me as well i really do appreciate it !
JUNI0R
ahhh good to hear and no worries! I’m glad we’ve been of some help. Let us know of your final spec before your order so we can do a double check. Also @Nursemorph raised a good point about having 2SSD’s (one for Windows one for games) which might be worth considering as your budget seems to be quite large
