new battery for recoil II 15.6"
AndroiFy
Hi everyone,
I cannot see which model of battery is using the recoil II. I need a new one because looks like the maximum capacity is 18,240 mWh and turn off immediately at 60%.
Someone knows the correct model for this laptop? Exist a wider one?
Thanks in advance!
Hi everyone,
Thanks in advance!
Is this a PCSpecialist machine? Could you post your full specs from the order page?
AndroiFy
Yes, it is from PCSpecialist.
Chassis & DisplayRecoil Series: 15.6" Matte Full HD IPS 144Hz 72% NTSC LED Widescreen (1920x1080)
Processor (CPU)Intel® Core™ i7 Six Core Processor 9750H (2.6GHz, 4.5GHz Turbo)
Memory (RAM)16GB Corsair 2666MHz SODIMM DDR4 (2 x 8GB)
Graphics CardNVIDIA® GeForce® RTX 2060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
1st Storage Drive120GB ADATA SU650 2.5" SSD, SATA 6 Gb (520MB/R, 320MB/W)
Memory Card ReaderIntegrated 3 in 1 Card Reader (SD / SDHC / SDXC)
AC Adaptor1 x 180W AC Adaptor
Power Cable1 x 1 Metre Cloverleaf UK Power Cable
BatteryRecoil II Series 46WH Lithium Ion Battery
Thermal PasteCOOLER MASTER MASTERGEL MAKER THERMAL COMPOUND
Sound Card2 Channel High Def. Audio + SoundBlaster™ Cinema
Bluetooth & WirelessGIGABIT LAN & KILLER™ WIRELESS-AC 1550 M.2 GAMING 802.11AC + BLUETOOTH 5.0
USB/Thunderbolt Options1 x USB 3.1 PORT (Type C) + 2 x USB 3.1 PORTS + 1 x USB 2.0 PORT
Keyboard LanguagePER-KEY RGB BACKLIT UK MECHANICAL KEYBOARD
Dimensions & Weight
Dimensions (w x d x h)359mm x 236mm x 22mm
Weight2.0Kg (inc. battery)
ColourBrushed black aluminium
Battery & Power Lead
Battery Capacity3 Cell Lithium-Ion battery (46WH)
Typical Battery LifeUp to 4 Hours
Power Lead & AC Adpater1 x Power Lead included with AC Adapter
Is it OK like that?
Dimensions & Weight
Is it OK like that?
You can order a battery through your online account.
