New Build, is it good?
Klasisc
I ordered a pc that is currently being built. I currently own a 1080p 25w monitor at 60Hz refresh rate, but plan to upgrade to a 4K 144Hz monitor sometime soon in the future. The main use is for gaming and multitasking while working from home. My overall budget (for the PC only, not counting the monitor) is £2500. Any suggestions to improve it would be welcome.
PCS PRISM-X ARGB MID TOWER CASE
Intel® Core™ i7 12-Core Processor i7-12700K (3.6GHz) 25MB Cache
ASUS® ROG STRIX Z690-A GAMING WIFI D4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
Graphics Card Support Bracket
PCS GRAPHICS CARD SUPPORT BRACKET
PCS FrostFlow 240 Series ARGB High Performance Liquid Cooler
Extra Case Fans
1x 120mm Black Case Fan
Windows 11 Professional 64 Bit - inc. Single Licence
Welcome Book
Logo Branding
PCSpecialist Logo
Klasisc
Thanks. I was doubting if the case was large enough and would impair the cooling. I will change it.
With regards to the PSU, is the 1000W that needed. Would a 850W suffice? I noticed that on the forums a lot of people recommend a lot more than 20% headroom? Are there any benefits outside of future upgrade to GPU?
Klasisc
Thank You so much for the input. I think your suggestions make a lot of sense. I do however want to add that I have a bramd new external Samsung 500 GB SATA SSD 6000MB/R at home and I thought a 1TB drive would be sufficient. But am I winning that much more speed by using a small and fast drive to load windows and apps is better than a large and slower one?
Klasisc
Update:
This is what I have settled on as a final. I know some things may be slightly out of balance (The RAM and motherboard), but I wanted to invest the money now to later have a bit more flexibility with upgrades down the line.
Corsair iCUE H115i RGB PRO XT Hydro Series High Performance CPU Cooler
Welcome Book
Logo Branding
PCSpecialist Logo
Thanks @JustARandomPerson for you input. This is the 1st time I ever decided to get a PC built though I knew what I wanted in terms of main components, but didn't know how to optimise/balance the other build components that would complement my GPU/CPU choices.
sck451
Update:
Welcome Book
Logo Branding
PCSpecialist Logo
That looks outstanding to me, absolutely exceptional. The only thing I'd wonder would be the cooler: since you have the shiny RGB case fans, you may like to have the cooler fans to match, which would mean the H150i Capellix instead, which is about £30 more IIRC. But there's nothing else I'd seriously consider altering.
