New pc but unsure of monitor
dardob
Hi there
After reading through some posts here I have gone for the following spec.
PC is for playing games only. Mainly fps multiplayer like warzone, quakelive, csgo, some warcraft and grand theft auto
What I cant decide is should I get a 1080p monitor with 240hz or 1440p monitor.
It's rare I play single player games
Thanks for any advice
Also can anyone confirm current buildtime
Is it actually 13-15 days or alot longer
CORSAIR OBSIDIAN SERIES™ 500D SE CASE
ASUS® ROG STRIX X570-F GAMING (USB 3.2 Gen 2, PCIe 4.0) - RGB Ready!
8GB ASUS ROG STRIX GEFORCE RTX 2080 SUPER - HDMI, DP
NOT REQUIRED
1TB SEAGATE FIRECUDA 520 GEN 4 PCIe NVMe (up to 5000MB/R, 4400MB/W)
DVD/BLU-RAY Drive
NOT REQUIRED
LED Lighting
2x 50cm RGB LED Strip
NO OPERATING SYSTEM REQUIRED
NO RECOVERY MEDIA REQUIRED
Price: £2,489.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/u8ARZwxRTS/
That build is completely unsuitable for 1080p, it's for 1440p ultrawide or 4k. 1080p is a completely dead format except for competitive esports.
What's your budget for the monitor?
The build times are just estimates, it doesn't guarantee it will be built in that time.
This would be better balanced on the PC:
CORSAIR iCUE 465X RGB GAMING CASE
NOT REQUIRED
DVD/BLU-RAY Drive
NOT REQUIRED
LED Lighting
Price: £2,261.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/DsURnyVjxh/
Then if you add what you've saved to the monitor budget, you can get a top end 1440p Ultrawide:
This Asus is well worth a look at around £700:
dardob
Thanks for that spyder
Do you think that would be able to maintain high fps at that resolution in a multiplayer game of warzone without any big fps drops?
dardob
Thanks for all your help spyder
What is the difference between a
11gb geforce rtx 2080 ti
And
Asus 11gb rog strix geforce rtx 2080 ti
And
They will both perform very similarly. With the STRIX you're pretty much paying for the brand, and it's a LARGE premium for the name. That being said, you will get a known card whereas the stock option would be unknown unless you called and asked.
