New PC for MSFS, DCS and Houdini FX
Dam0
I'd ordered the below and after reading a few comments on this forum amended the order to upgrade the PSU and cooling already.
I use my PC everyday for work, gaming (MSFS/DCS) and some hobby modeling / FX work with Houdini and Nuke. I'll be taking the GFX card from my old PC and transferring a few extra SSDs too.
Comments welcome, it's still in pre-prod.
CORSAIR 4000D AIRFLOW TEMPERED GLASS GAMING CAS
Intel® Core™ i9 16-Core Processor i9-12900K (3.2GHz) 30MB Cache
ASUS® ROG STRIX Z690-A GAMING WIFI D4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
32GB Corsair VENGEANCE DDR4 3600MHz
NONE, I ALREADY HAVE A GRAPHICS CARD (Will be fitting a RTX 2080ti from my current PC)
1TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
External DVD/BLU-RAY Drive
8x Slim USB 2.0 External DVD-RW
Corsair iCUE H150i RGB PRO XT Hydro Series High Performance CPU Cooler
sck451
Looks great. My only question would be about storage: what other storage devices will you be adding? There might be a way of doing this more efficiently...
As above, I don't think 1-1-1 is a particularly good shout.
I would opt for:
500GB 980 Pro for a primary
2TB Intel 670p for games & fast storage
Your other SSDs would do fine for the mass storage and/or cache.
I wouldn't go higher than 500gb for the primary as you don't want to over-use this drive. It keeps it running full chat and also makes it easy to reset when you want/need to.
Dam0
Thanks guys,
I'd be putting in an additional 2 x 1TB SSDs and a single 1TB mechanical HDD also.
As a preference, I tend to segmentation off entire drives depending on the purpose. OS / Games / Programs / Caches / Footage Storage all goes on to different drives.
Thanks guys,
To a certain extent I'm the same. I always have my programs & OS on the same drive right enough. However, all that said I always limit myself on the primary OS drive. Going OTT just makes it a pain when it comes time for a format.
Backing up 100GB is much easier than backing up 400GB :D
