Just to confirm, have you tried turning up the volume?i have tried without the splitter and also my logitech speakers are not working either
You need to install the optional updates as @Martinr36 says.
just did them and nothing changed, thank you thoughYou've got optional updates there, they need installing
Bullguard causes more problems than it cures
Have you uninstalled bullguard?just did them and nothing changed, thank you though
yes and i made sure, windows defender is onHave you uninstalled bullguard?
Sorry, having to backtrack a lot cos you're missing questions. Have you tried raising the volume? It's currently on minimum.yes and i made sure, windows defender is on
But it still doesn't work
yeah i have just turned everything up to 11, nothing is still happening,Sorry, having to backtrack a lot cos you're missing questions. Have you tried raising the volume? It's currently on minimum.
What speakers are you plugging in amd to which port?yeah i have just turned everything up to 11, nothing is still happening,
A soundcard would bypass any audio from the on board sound. But the OP doesn't have a soundcardWhats the difference between the rear audio ports and the case ones?
Just when my PC came I had a sound card (i dont use it) but I had instructions from PCS to plug any external audio devices into soundcard ports and not the motherboard audio ports or I would get no sound.
Ok, you need to just answer the questions directly if possible.just some logitech z200 i got from argos, nothing special but will do the job until i can get something more better
they work find in the top port just not the rear ones, so i no they work
And they're turned on and turned up? Have you checked the windows volume as that will reset depending on what device you have plugged in.i have tried a normal set of headphones and nothing happens
i have plug it into every port, but at the moment, the speakers are in the audio/line out which is the "green" coloured port
What headphones are they?i have tried a normal set of headphones and nothing happens
some wired Sony headphones I purchased 2-3 years agoWhat headphones are they?
Is the headset USB as that has it's own on board soundcard which is why it has it's own selection.I have this option available but I need to select the other option for speakers which is the make of my speakers/audio box or my headset make (razer)
Do they have a microphone on them?some wired Sony headphones I purchased 2-3 years ago
Everything is turned up
To be certain though, can you right click on the audio in the bottom right of the task bar and select "sounds" and take a screenshot of the Playback window?Is the headset USB as that has it's own on board soundcard which is why it has it's own selection.
These are analogue so wouldn't have their own selection.
no, just audio i use for travel, i tried plugging them into the back (and every port) and nothing happens but the top ports doDo they have a microphone on them?
