No power to laptop
Starkie
Morning All,
Had this latop for a year and a half and its been fantastic.
However last week - it stopped charging when plugged infor about 20 mins - then it was fine for the rest of the day. Then a day later same thing but it took about 8 hours for it to realise it was plugged in and starting charging ( it was off for most of this time ) , and now it wont charge at all to the point it's flat.
My first throught was the power pack ( on order ) - Just wondered if the battery could also cause this. To stop the laptop realising its plugged in?
Cheers
Chassis & Display
Ionico Series: 17.3" Matte QHD 240Hz sRGB 100% LED Widescreen (2560x1440)
Intel® Core™ i7 14 Core Processor 12700H (4.7GHz Turbo)
64GB Corsair 4800MHz SODIMM DDR5 (2 x 32GB)
NVIDIA® GeForce® RTX 3070 Ti - 8.0GB GDDR6 Video RAM - DirectX® 12.1
AC Adaptor
1 x 280W AC Adaptor
Battery
Ionico Series Integrated 91WH Lithium Ion Battery
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6E AX210 (2.4 Gbps) + BT 5.3
1 x USB 3.2 PORT (Type C) + 3 x USB 3.2 PORTS
Keyboard Language
IONICO 17 SERIES RGB BACKLIT UK KEYBOARD
Carry Case
Tech Air 17.3" Classic Backpack
Keyboard & Mouse
Webcam
INTEGRATED 2.0 MP FULL HD WEBCAM
Standard Build - Approximately 3 to 5 working days
Welcome Book
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/ionico-iii-17/u0AScvK7Vs/
There is a tool called HWMonitor which has a battery report of wear level.
Modern systems are different with regards to batteries than older ones, as systems have got so powerful, even when plugged in they often still use battery as well and some won’t allow powering on if the battery is dead.
Sometimes you do get dud batteries that die pretty quickly so if you’re able to get it booting again it’s definitely worth checking the wear level.
Batteries are classed as consumables so only carry a 6 month warranty.
Starkie
Hi @SpyderTracks - appreciate the advise. I can't get it to boot sadly. Is it worth me removing the battery and seeing if it will power up direct from the mains?
Or is it better to see if the new ac adaptor does the trick?
That’s what I’m saying though, a lot of devices won’t boot without the battery. Certainly give it a go though
