Nvidia 3080 TI
dickymint999
My current Graphics card is 8GB NVIDIA GEFORCE RTX 2080 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
My PC was built and supplied by PCSPECIALIST (more than happy customer).
Case PCS P209 RGB MID TOWER CASE
Processor (CPU)Intel® Core™ i9 10 Core Processor i9-10900X (3.7GHz) 19.25MB Cache
MotherboardASUS® PRIME X299-A II: ATX, USB 3.2, SATA 6 GB/s, ARGB Ready
Memory (RAM)32GB Corsair VENGEANCE DDR4 2666MHz (4 x 8GB)
Graphics Card8GB NVIDIA GEFORCE RTX 2080 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
1st Storage Drive2TB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 470MB/W)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 750W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingINTEL SOCKET 2011/2066 STANDARD CPU COOLER
Sound CardONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Wireless Network CardWIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD
USB/Thunderbolt OptionsMIN. 2 x USB 3.0 & 6 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
I am considering upgrading my graphics card to a 3080 TI. I just wanted to check that I would have no issues with replacing the existing card with the new card.
Also is there a market for a second hand RTX 2080 Super card ?
regards
MrWilson
Your PSU is too small for me to endorse adding a 3080ti as they can draw tremendous amounts of power at full throttle. I would want at least 850W in there, and probably 1000W in all honesty.
I’m also not too sure about having it in that case, the thermals aren’t great and your cooler selection doesn’t help that so it might overheat a little.
RIP Julee Cruise ☹️
In addition, on the configurator it states that the case can only support GPUs with a length of 32cm and that the 3080Ti is 33cm+
Unfortunately that's not a well configured system with any sort of upgrade potential in mind. I'm surprised it's performing well in all honesty as it's a hot thing in a hot box without any well defined cooling solution. Would recommend that you get some guidance on the forum for the next big upgrade to try and avoid such a situation :)
  • Like
Reactions: Aza
dickymint999
Thanks everyone, it was well worth the post.
A follow up question if I may.
Can anyone recommend a GPU upgrade that would be beneficial and suitable for me spec
Thanks in advance.
