There's your problem then. NEVER use driver search and install tools - they lead to bad/wrong drivers and issues like this.Firstly used Driver easy.
Is this a Clevo model or TongFang? Look for the label on the bottom.ok , reinstalled windows again from bootable media.
installed all drivers from PCS Download section but can't download VGA_W10 . when nearly finish download get info its unsucessfull
ClevoIs this a Clevo model or TongFang? Look for the label on the bottom.
As above, you'll need to do another clean installation as you've compromised the system with Driver Easy.
done that already . after clean installation i installed all drivers from PCS Download section . thats it .As above, you'll need to do another clean installation as you've compromised the system with Driver Easy.
Then allow windows updates to install all drivers it can.
Then post back once you've applied all windows updates with a screenshot of your device manager.
If it's a clevo, then those drivers will be out of date.done that already . after clean installation i installed all drivers from PCS Download section . thats it .
Will do that now.You need to allow windows updates to install all drivers, then install nvidia direct from nvidia and hotkey direct from www.clevo.com.tw
I don't know what laptop you have? It's a normal drivers page, you find your model and it will list all drivers for it.Will do that now.
can you send me proper link to hotkey ?
Check model and unfortunately i can't find hotkey for this model . its NH55DDI don't know what laptop you have? It's a normal drivers page, you find your model and it will list all drivers for it.
It's there? Where are you having issues? It's also called control centerCheck model and unfortunately i can't find hotkey for this model . its NH55DD
yes , i found that but there is not hotkey to download
it's part of control centreyes , i found that but there is not hotkey to download
It's likely a hardware issue then. That dump was very clear.unfortunately after reinstalled windows , install drivers and hotkey still not been fixed.
You said in your OP you've had other BSOD reasons? Do you have any dumps from those??
now its off. but when open game its between 50 to 75What sort of temperatures are you seeing on the GPU?
These are exactly the same as before - nvlddmkm.sys, the Nvidia graphics driver is the problem.....Microsoft OneDrive
1drv.msMicrosoft OneDrive
1drv.ms
Uninstalled the nvidia drivers and installed new one . nothing change unfortunatelyThese are exactly the same as before - nvlddmkm.sys, the Nvidia graphics driver is the problem.....
In that case - and if you're sure you clean installed Windows, deleting all UEFI partitions, ran Windows Update until no more updates were found, and installed nothing else except for the bare minimum software you need to test it - and it still fails then its a hardware issue, like the GPU.Uninstalled the nvidia drivers and installed new one . nothing change unfortunately
