shafiq
Hello ...
I've spec'd up a couple of machines on the PCS Website.
We're predominantly going to be using them with the range of Adobe Products - Photoshop, Illustrator, InDesign & Dreamweaver (We're a Web Design / Photography & Print Agency)
The spec is as follows:
Case: COOLERMASTER SILENCIO 550 QUIET MID TOWER CASE
CPU: Intel® Core™i7 Six Core Processor i7-4930K (3.4GHz) 12MB Cache
Motherboard: ASUS® P9X79 LE: INTEL® SOCKET LG2011
Memory (RAM): 32GB KINGSTON HYPERX GENESIS QUAD-DDR3 1600MHz X.M.P( 4 x 8GB KIT)
Graphics Card: 2GB NVIDIA GEFORCE GTX 770 - 2 DVI, HDMI, DP - 3D Vision Ready
2nd Graphics Card: NONE
3rd Graphics Card: NONE
1st Hard Disk: 240GB KINGSTON V300 SSD, SATA 6 Gb (450MB/R, 450MB/W)
2nd Hard Disk: 2TB WD CAVIAR BLACK WD2003FZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
RAID: NONE
1st DVD/BLU-RAY Drive: 24x DUAL LAYER DVD WRITER ±R/±RW/RAM
2nd DVD/BLU-RAY Drive: NONE
Power Supply: CORSAIR 650W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor Cooling: INTEL SOCKET LGA2011 STANDARD CPU COOLER
Thermal Paste: STANDARD THERMAL PASTE FOR SUFFICIENT COOLING
Operating System: NO OPERATING SYSTEM REQUIRED
We intend to run the above machine on Windows 7 Pro 64 Bit.
Do you think this will be suitable?
I believe the graphics card can make a difference in terms of performance - I've been recommended using the Nvidia Quadro range of cards but that blows out our budget.
Comments?
Many Thanks
RAID: NONE
Comments?
Many Thanks
