PC Build Help | PCSPECIALIST
PC Build Help
roblou
Hi everyone,
First time looking at a Custom Build PC, and first time posting here so apologies in advance for silly questions and lack of knowledge! :)
I am looking for a Gaming PC, currently i play games like WoW, Skyrim, 7Days2Die, Dawn of War, Civilisation and recently got an Occulus as well. Below if a build i have come up with, and looking for some advice on changes (if required). I'm running a Wireless Internet.
EDIT - I am currently using a 1080, 60Hz Monitor, and ideally i'm not looking to spend more than £2000 total.
COOLERMASTER MASTERCASE H500 GAMING CASE
The Outer Worlds -OR- Borderlands 3 w/ select AMD Ryzen CPUs
ASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - RGB Ready!
8GB NVIDIA GEFORCE RTX 2080 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
1TB ADATA SX6000 Pro PCIe M.2 2280 (2100 MB/R, 1500 MB/W)
DVD/BLU-RAY Drive
NOT REQUIRED
Corsair H100x Hydro Cooler w/ PCS Ultra Quiet Fans
LED Lighting
50cm RGB LED Strip
Extra Case Fans
ASUS PCE-AX58BT WiFi 6 (802.11ax) 2400Mbps/5GHz, 600Mbps/2.4GHz
Standard Build - Approximately 12 to 15 working days
Price: £2,024.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/byVC6ARUdJ/
And tips and recommendations are appreciated :)
Rob
32gb is a waste for gaming, 0 benefit and by the time gaming could benefit, your gaming PC won't because everything else will be obsolete.
WoW and Fallout 4 built on the same engine as Skyrim can see huge benefits from faster RAM though so 3600MHz could be worth it
Don't buy that wifi card, it's hugely expensive.Stick to the £8 one or source your own for ~£20
For an RTX 2080 Super, a 1080p monitor is a massive waste of its potential. You should be looking to 1440p 144hz
X570 motherboard isn't necessary here, B450 is fine.
DVD/BLU-RAY Drive
NOT REQUIRED
STANDARD AMD CPU COOLER
Price: £1,608.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/dCRGxQc70t/
This leaves you the ~£400 or so to get a decent monitor too.
roblou
That's brilliant :) Thank you!
I do currently have a USB WiFi Adaptor, was just thinking that a built it one may be better. However i shall just keep the one i have if wouldn't make much difference.
With regards to the extra Fan Option, is that worth it in your opinion? Or would just be for aesthetics? On my Build above i had put in the 3x Corsair LL120 RGB LED Fan + Controller Kit
If your current wifi adapter is fine, keep using it :)
I wouldn't bother with the extra fans. They're not needed, and will save a significant amount of money towards getting a monitor worthy of the system.
roblou
Almost finished deciding, so final few questions :)
Confirming the Power Supply shown below will be sufficient, and i have now including a new Monitor in the Build below. It would be ideal to be able to run 2 monitors. The one i currently have (1080p 60Hz), and the new one.
Will i be able to do that with this build? And if so, what would i need extra? If anything.
Corsair H60 2018 Hydro Series High Performance CPU Cooler
Monitor
MSI 27" Optix MAG271CQR - 2560 x 1440, 1MS, 144Hz
Promotional Item
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/eEqyCkf27W/
Looks good to me :)
You can ofc shop for monitors elsewhere too. Maybe you can find the same thing cheaper, or you might find a lot more to choose from. There's a mini list here:
But that MSI is a good option
roblou
My current Monitor plugs in with a Displayport Cable. Does this build have the 2 working DP Ports? Just clarifying as i had a nightmare when i got the Occulus and had to change from HDMI to DP. Felt like i had loads of ports at the back, but only a small portion of them actually worked :D lol
I shall take a look at that Guide, thank you :)
Im planning on placing the order tonight which is exciting :D
The GPU has 1 HDMI and 3 DP which is pretty standard for high end Nvidia GPUs
Exciting times indeed - colour me jealous :D
roblou
Amazing.
Thank you for your help! Much appreciated, and very handy as i am a Monitor as well, for the same price as my original build :D
