Pc build help | PCSPECIALIST
Pc build help
patodr
Hey, I dunno where to post this.
But I need a new gaming pc, Iv no idea on what parts to put in it.
I will be gaming & streaming, and using vr so I’ll need a usb type-C port ,
Also I want 32gb of ram.
Also if the pc could handle all that it would be great .
i 100% do Not want a liquid cooled pc. Their not for me.
Nursemorph
Big Poster
Is this not the system you bought? If so, then that is the same base system as would be recommended for what you want....just add another 16GB RAM if you really want 32GB. I literally specced up an identical systsem for streaming the other day (asides from a newer GPU):
NZXT H500 MID-TOWER GAMING CASE (BLACK)
ASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - RGB Ready!
11GB NVIDIA GEFORCE RTX 2080 Ti - HDMI, 3x DP GeForce - RTX VR Ready!
DVD/BLU-RAY Drive
NOT REQUIRED
Noctua NH-U14S Ultra Quiet Performance CPU Cooler
Extra Case Fans
Windows 10 Professional 64 Bit - inc. Single Licence
Firefox™
Monitor
IIYAMA G-MASTER GB2760QSU-B1 27"
Microphone
Audio-Technica AT2020USB+ Condenser Microphone
Price: €3,364.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.ie/saved-configurations/amd-am4-gen3-pc/abZfFPjvt8/
Huntsman
I ended up buying a pc from a different vender. Now it’s fried :/. So this time I’m definitely buy from here as Iv heard all good things . The only thing is. My budget is 1,500
I would hold off for a week or so as the 3070 plus the new AMD chips are being released and they would fit a £1500 budget perfectly, so you’d be looking at entry level 4k or high end 1440 ultrawide performance.
patodr
im not bohered about the 4k. i do need a monitor aswel, currently iv 2 monitors, one hmdi dell one and one old accer, vga monitor, so id like upgrade the vga monitor to a hdmi one aswel.
what you you suggest for now? 3 things i require;
no liquid cool,
i need a usb type-c port.
and i want 32 gb of ram
Huntsman
no liquid cool,
Like I say, I wouldn't buy now, you're literally 2 weeks away from significantly more power at the same price.
patodr
i no what your saying but at the same time, parts would be cheaper now aswel :p. iv a vr headset coming in less that a week, and just wann buy a propper pc for my budget.
Huntsman
But that's the point, the current 2000 series cards are much MORE expensive for less performance, and the upcoming 5000 series CPU's are SUBSTANTIALLY more powerful for around the same cost.
You wouldn't be able to build what you required in your budget, it would require a 2070 Super which would take you over budget.
With the 3000 series, you'd be able to afford a suitable system.
Even if you order now, you wouldn't receive it for a month anyway.
patodr
oh dam, :/ i guess il have to wait. what date are they supose to be out?
Nursemorph
Big Poster
You'd need to ask PCS themselves whether they will be updated to the new hardware...preumsbaly that will be the case but nothing is guaranteed these days.
As to whether they are any good, depends which one..of the current selection, I personally wouldn't order any of them....the FNATIC Pro and Ultra I'd consider if they had an NVIDIA GPU in them
patodr
ah ok
