PC for gaming and deep computer vision
GameDos
CORSAIR 175R RGB MID TOWER GAMING CASE
12GB NVIDIA GEFORCE RTX 3080 Ti - HDMI, DP
1 x 1 Metre European Power Cable (Kettle Lead)
PCS FrostFlow 120 Series RGB High Performance Liquid Cooler (AMD)
Extra Case Fans
NOT REQUIRED
Price: €2,996.00 inc VAT and Delivery
Monitor: Anything full HD or above is fine with me; refresh rate > 60 Hz
Use: Gaming and deep computer vision (thus the need for a large VRAM since I would need to store training image data while running model training)
Budget: The ceiling is 3K, but I would really like if I could go lower
steaky360
Hi, can you add the link to your config: https://www.pcspecialist.co.uk/foru...ification-to-the-forum-check-this-spec.73718/
Other useful questions which will likely come up : https://www.pcspecialist.co.uk/foru...posting-collaboration-of-helpful-hints.77691/
I have no clue what is required for 'deep computer vision' in fact I'll have to google it to really have a good idea what it is... so I'll leave any spec suggestions to others. But since you need more VRAM is the 3090 worth considering? Its got SIGNIFICANTLY more VRAM, although does cost a fair bit more so would annihilate your budget.
