Ok, because you said you installed them allthe ones which you linked I just insalled the amd chipset drivers for my motherboard
As above, you'd need to clean install.Ok, what should I do then?
If your files are on the c drive, then you need to copy them off before you reinstall.How would I do that? Would that mean that I would loose all of my files
Let's leave that for now, you're jumping the gun a bit. You'll need a separate thread on that as it's not related to this.also, I am buying a new graphics card which one do you think would be a good match with my ryzen 9 5900x?
sorry, I'm not really to sure how to check or do thatIf your files are on the c drive, then you need to copy them off before you reinstall.
But on a properly configured PC your data will always be on a secondary drive which is separate to windows.
Where have you been storing your data? Only you would know that, whenever you save something it asks you where to save it.sorry, I'm not really to sure how to check or do that
C drive is windows. You never want to store any data on that unless it's in cloud storage. You always store data on a secondary drive.I save it on an ssd called windows C, I also have a hard drive however I havent stored anything at all on it
Hard drive doesn't matter with speed for data, doesn't make a difference.but my secondary drive is a hard drive isnt that much slower? also how would I copy all the data over to it?
You only move your data. You can't move the windows contents.Ok thanks, so once I've moved all the storage over and the Windows C drive is clean what do I do
No, C is the windows drive. You can't copy any windows files, you can only copy your data files.ok so do I litterally just copy all the files from windows c to d?
