Pc Spec, a few questions.
here you go this is what i'd propose, I've swapped the CPU to a more up to date one, tweaked storage, changed case, and upped the PSU
Standard Build - Approximately 13 to 16 working days
Price: £2,083.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/3djEFS58cF/
CarRos
Hi Martin, thanks for your reply. Out of interest why the Ryzen 7 over the 9? Just a cost saving? Does the case you've gone for offer any advantages other than it's aesthetic? Lastly is the intel storage just slightly cheaper as it is running a tad slower than the seagate? And yeah, a quiet power unit is definitely a want for me, thanks for that!
The 3900 is the last generation and surpassed by the 5800x, the case i picked is better cooling than the one you chose and with the 5800x being the hottest running of the 5000 series cooling is everything, I upped to that PSU not just for quietness but also to give you overhead for upgrades in the future.
those intel 670p are great little drives I've got one in the Berserker in my signature
CarRos
Threads got merged and I lost your previous comment Martin. Here is my reply.
Thanks Martin, I had a play around again. Upped the 3900 to 5800 12 core. I dropped the water cooling. The case you chose didn't have compatibility with the motherboard for USB c, the only one I could find that had USB c support was over budget and I didn't think it essential to have it on the case there. I did take the PSU back to 650 for now as well just to drop the budget a tad. Also dropped the data drive as I'll use an existing one. Anyway, I'd be interested in your take on this setup.
COOLERMASTER SILENCIO S600 QUIET MID TOWER CASE
PCS FrostFlow 240 Series RGB High Performance Liquid Cooler (AMD)
Welcome Book
Logo Branding
PCSpecialist Logo
Price: £2052.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/8hSznJ7c9J/
It will cook and be under powered with no room for future upgrades and you're only about £30 cheaper than the spec i did, personally I can't see why folk are so infatuated with USB C, I've one usb c port on my mobo and a long lead plugged into it which hardly gets used
CarRos
Thanks again Martin, I just wasnt sure if I wanted to bother with a case that has usb c that doesn't work. That's all, I hardly use it myself although it seems to be the way things are going with EU regs coming in. With regard to the cooling aspects are you saying the case you've chosen has more room for future upgrades and will generally allow for more airflow? Thanks for answering all the questions, I appreciate your time.
Yep, exactly that, the case is one of the most important parts of a build, if you don't have good cooling, then things will start to thermal throttle.
For future upgrades you'll need the higher powered psu that i put in my spec
CarRos
Thanks. What is bugging me now is the motherboard in my original spec is out of stock and I am having to go for the cheaper and not as high rating one I have. Originally I had this one - ASUS ROG STRIX X570-F GAMING
You could give them a bell see when its likely to come back in stock, i had heard early/mid next month
JUNI0R
The STRIX B550 is a really solid board, yes it's not ideal but it's knocking on the door of a lot of the X570 boards, I'd be happy to suggest that with the 5900X. The other option is the Crosshair which goes the other way but that's a 5950X tier motherboard really
sck451
The Crosshair is the "I want the best motherboard" option. The Strix B550 is the "I want a great motherboard at a reasonable price" option.
X570 and B550 are a bit weird. Because X570 came out earlier, lots of the boards are actually not that far ahead of the equivalent tier B550 board and sometimes behind them in some features. Unless you are running a major overclock or are making heavy use of the PCIe lanes, a top-end B550 board is almost all you need in most circumstances.
I think it might be back in stock
