pc v dell
jimcon
Dimensions & Weight
Dimensions (w x d x h)377mm x 259mm x 24.2mm
Weight2.2KG including Battery
Chipset
ChipsetSupports 8th Generation Intel Core Processors
Memory
Memory TypeSupports DDR4 2400MHz
Number of Modules2 x 1GB/2GB/4GB/8GB/16GB Modules
Maximum Supported Memory32GB
Hard Drive Capacity
Hard Drive Type1 x 7mm, 2.5" S-ATA HDD support
M.2 Port1 x M.2 2280 Port
Display & Graphics
GraphicsIntel® HD Graphics 620
Screen Size15.6 inch Widescreen
Native/Maximum Resolution1920 x 1080
BacklightLED
Audio
ChipsetIntel High Definition Audio
Channels2 channel HD Audio
ConnectionsMicrophone-in and headphone-out
SpeakersBuilt in two speakers
Integrated MicrophoneYes
Communications
LANGigabit LAN
Wireless SupportWireless LAN 802.11B/G/N Half Mini Card module
Bluetooth SupportBluetooth V4.0 module support
Webcam1.0 MP Webcam
Firewire (IEEE 1394)N/A
Expansion Slots
TV TunerN/A
Keyboard & Mouse
KeysMulti Language A4 size Floating Keyboard
Language SupportMulti-Language support
Pointing Device | Touchpad MouseBuilt in touch pad with multi-gesture and scrolling function
Memory Card Reader6-in-1 Card Reader (MMC / RSMMC / SD / Mini SD / SDHC / SDXC)
Ports
i bought a dell which would not work sent it back and bought this from pc man this is soooo much better. the components pc use are so much better
