PC won’t turn on
yosila
Hello, I bought my PC a few months ago and it’s been great so far, no problems, up until today. My PC will not turn on when I press the power button. The only lights I can see on the PC are at the back, where there is the usual orange light and a flickering green light around the Ethernet port. I’ve made sure the power cable is fully connected to the PC, and I’ve tried plugging the power cable into different sockets. Any help would be greatly appreciated :)
Specs:
CaseCORSAIR 4000D AIRFLOW TEMPERED GLASS GAMING CASE
Processor (CPU)Intel® Core™ i7 12-Core Processor i7-12700KF (3.6GHz) 25MB Cache
MotherboardASUS® PRIME B760-PLUS D4 (LGA1700, PCIe5.0, USB 3.2)
Memory (RAM)16GB Corsair VENGEANCE DDR4 3200MHz (2 x 8GB)
Graphics Card12GB NVIDIA GEFORCE RTX 4070 - HDMI, DP, LHR
Graphics Card Support BracketNONE (BRACKET INCLUDED AS STANDARD ON 4070 Ti AND ABOVE)
1st M.2 SSD Drive1TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 2950MB/sW)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 750W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Power Cable1 x 1.5 Metre UK Power Cable (Kettle Lead)
Processor CoolingDeepCool AG620 ARGB High-Performance Dual Tower CPU Cooler
Network CardONBOARD LAN PORT
Wireless Network CardWIRELESS INTEL® Wi-Fi 6E AX210 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
Operating SystemWindows 11 Home 64 Bit - inc. Single Licence [KUK-00003]
Windows Recovery MediaWindows 10/11 Multi-Language Recovery Image - Unlimited Downloads from Online Account
Anti-VirusNorton 360 inc. Game Optimizer - Free 90 Day License
BrowserGoogle Chrome™
Keyboard & MouseRazer® BlackWidow V3 Tenkeyless (Green Switch)
Warranty3 Year Standard Warranty (1 Month Collect & Return, 1 Year Parts, 3 Year Labour)
Have you opened your machine and checked for any loose wires coming from the PSU and leading to the motherboard / GPU etc.
It doesnt sound like it is the PSU as you are getting some lights come on but cables may have come loose.
Do you get any beeps at all or any movement in the fans?
Also check the CPU motherboard cable hasn't come loose, it's usually and 8pin, sometimes plus a 6 pin, usually located top left of the motherboard.
What happened immediately prior? Was there a power cut at your house? Have you opened it up at all? Did you move the PC? Have you installed any updates?
