PCS SR-628B RGB GAMING CASE Advice | PCSPECIALIST
thomor
Looking to put my new build into this case as I like the look of it and it fits nicely into my budget.
The only thing I'm confused about though is that the front panel looks solid, it has 3 intake fans and doesn't look like there is sufficient access to the open air for enough intake. I'm adding 2 extra extraction fans to it and putting a R5 3600 + RX 5700 in it. Is it going to be good enough with that front panel?
I wouldn't.
if you're buying a case and add more fans, it's usually better to just buy a better case where you don't even need to add more fans.
Furthermore, if the front fans aren't getting much air then you could end up with negative pressure from the extractor fans, which isn't ideal.
Just go for the Corsair 460X. It's only £18 more once you take into account the fact you don't need to buy extra fans with it, and it's a very decent case.
